Help with t-rex cam
Help with t-rex cam
i have an 02 Z28 with a stock LS1 and im about to buy the t-rex cam but what also do i need to buy besides lifters, retainers, and springs??? thanks for your help.
You do not need to buy lifters. Cam, springs, retainers, spring seats, valve stem seals, hardened push rods, timing cover gasket, water pump gaskets. The best thing would be to order TR complete cam kit, and gasket kit for the cam swap.
Thunder should be able to supply you with everything needed. The kit alone might cover everything. You WILL want steep gears and/or a high stall converter to make it work, and supporting bolt-ons.
