best timing chain
Old 05-04-2005, 10:10 PM
99SLOWC5's Avatar
Default best timing chain
I've done searches and haven't found any good evidence. I'm about to install a TSP 233/239 cam and bought the rollmaster double roller. Its a "JWS" chain, from what I can read through the bag. I thought I did read something about the rollmasters coming with 2 different brands of chains. One being better than the other. Should I be looking into a differnt chain or will this one be fine? I'm probably being to cautious and someone will hopefully tell me that
JEFF
Old 05-04-2005, 10:23 PM
blkZ28spt's Avatar
1) IMO, either chain should be fine.
2) You have the one you want regardless.
Old 05-04-2005, 10:29 PM
CorvetteAndy's Avatar
The dark colored gear is the heat treated one and comes with a bearing and a better chain. This is the one I use on all my engines.
Old 05-04-2005, 11:57 PM
sandking's Avatar
Or you can use a new LS2 chain and be done.
Old 05-05-2005, 12:04 AM
blkZ28spt's Avatar
True, but the man already has a better chain, whether or not it's "overkill".
Old 05-05-2005, 11:33 AM
99SLOWC5's Avatar
thanks for the replies guys. I guess I'll keep the Rollmaster and get the install underway.
JEFF
Quick Reply: best timing chain
