How do you reset PCM? Erase prior codes
Old 05-06-2005, 04:01 PM
ponchoWS6's Avatar
Default How do you reset PCM? Erase prior codes
Tripped a code last week and wanted to reset my pcm.
Old 05-06-2005, 04:13 PM
SS SLP2's Avatar
RESET SERVICE ENG LITE
& CLEAR CODES
F BODY LS1
1. Turn key on but don't start car.
2. Pull PCM BAT and PCM IGN fuses in engine compartment.
3. Wait a few minutes.
4. Turn ignition off.
5. Replace fuses.
RESET SEV ENG LITE & CLEAR CODES
5.3 TRUCKS
2. Pull ECM 1- ENG 1-ECMB fuses in engine compartment.
5. Replace fuses.
AFTER RESET ENG MAY TAKE A FEW MINUTES TO RELEARN IDLE AND TIMMING CURVE
Old 05-06-2005, 04:17 PM
txhorns281's Avatar
did you at least scan it? (I'm assuming you did...)
Old 05-06-2005, 04:53 PM
2001NBMZ28's Avatar
I'm with txhorns281 - would drive me crazy not knowing what it was...if it comes back on have it read at Autozone.
Quick Reply: How do you reset PCM? Erase prior codes
