Any hand helds worth the $
Howdy,
I'm thinking about a few mods. Are any of the hand held programers like Hypertech worth anything? Any suggestions would be great thanks.
Vinci is awesome.Before a mailorder I got a 12.27@112,after it I never approached that again.I dynoed the car and got 360/365 corrected and fell off at 5500 because of being pig rich.I got a vinci tuner and after I installed it redynoed and got 415/402 observed.The car is a bear and the 117 mph slips prove pretty got for a cam only w/bolt ons.
Originally Posted by dajodsterman
Howdy,
Originally Posted by mrr23
i'll third it. picked up .2 and 1.4 mph when the 00 formula was stock.
man that's a pretty good gain. I've been doing a little searching on the vinci sounds like a really good product. Do you know if it can turn off the ses light for codes like the EGR and the AIR? How does it compare to HP Tuners or LS1 Edit. I know those two aren't hand helds but I just wanted to know how much the vinci can do. I'll probably never do anything internal just bolt-ons but I would like something that would give me a good tune and get rid of that ses light without pulling the bulb. Thanks for all the info guys.
you can check codes and erase them with it also. here's a tutorial i made for the vinci/crane tuner. http://www.stealthram.com/vhptuner.htm
I like the Hypertech cause a) it only set me back 200 cause I had one for my 00 silverado, B) gas milage and being in CA 2.6 to 2.83/G for 91
2000 6SPD 65,000 MILES. MOD: HYPERTECH, WS6STORE SHORT STICK, FLOWMASTER MUFFLER, MONROE SENSE-A-TRACK SHOCKS, SLP LID & BELLOW
Howdy,
F*CK NO!!!!!!!!!!!!!!
HyperCRAP is a POS (I got talked into one when I first got my car 4 years ago.......after 6 months I realized what a POS it was and why my car pinged like a MotherFU*Ker all the time....... ).....
the actual "tuner" hand helds (like the predator) are the "worst" level that should be looked at and then only if you do not have a laptop/access to one....
if you have a laptop/or a friend with one.......there is NO reason to buy anything but HPTuner (had LS1Edit for 2 years......LS1Edit = SH*T compared to HPTuner in so many ways......) or EFILive (if you have the money)......
even if you don't NEED to tune a whole lot (like you don't have a cam), GET IT ANYWAYS! You will pay %60-75% of HPTuner's cost with those BS "handhelds" and if/when you ever do more you will be back spending more......
I'm a newby at this tuning stuff guys and well doing this retro fit into my 86 camaro out of a 02 is really getting me into some jams.... I am wondering first off where to get HP tuners and second of all what all is required i have a laptop sitting beside me but has windows xp on it so i imagine it will be able to run this hp tuners but it sounds like i need cables and stuff to get info to one form the other computer haha as always anywasy any info on this type of stuff would realy be appreciated as I plan on doing all my own work Boooo to speartech or painless.... no they are great but i haev an entire car so why not take some credit for the work eh????
xp works fine with it, I've run it on a laptop as slow as 300mhz before without issue. right now you'll need a usb to serial adapter (not belkin or radio shack) if you don't have a serial port... I do this and never had a problem... the 2.0 hardware will be an option for USB
Originally Posted by horist
www.hptuners.com
when you order HPT you get 1 cable and 2 licenses ... the licenses are year and model based... so a 2000 V8 F-Body license will work on any 2000 V8 F-Body unlimited number of times...
basically whichever licenses you choose on the order page, you can read/write any vehicle that falls under that year and model .
ok thats good maybe i can make some back on this with my buddies car. as well do i not get the flash,edit and scanner software with?????? to make it all work correct
yup the software includes an editor, a flasher, and a scanner and 1 cable. the software works w/the cable you receive and can be used on any car you have a year/make license for. You'll also get the 2.0 software once released
