do i have enough gas for a 75-100 shot
Coal Mining Director
For a dry kit to be safe you need both. I'd do 42lb svo's since it isn't that much more money and it will hold future additional hp. Plus a Racetronic fuel pump kit from Thunder,etc and you're set.....in the long run it's cheap insurance. If you haven'yt bought the dry kit you may want to search the n20 section for opinions wet vs dry. Good luck.
Originally Posted by Tally TransAm
also what size injectors if i need them
would svo 30's be ok or should i go bigger
