Threw a Code P1415. Can someone help me.
Old 05-11-2005, 01:33 AM
MetallicBluews6's Avatar
Default Threw a Code P1415. Can someone help me.
Threw a code. P1415 code I dont know where it is or where to fix it??????
Old 05-11-2005, 01:34 AM
What is it what does it mean?????????
Old 05-11-2005, 01:53 AM
blkZ28spt's Avatar
If you search around the site you can probably find something about it.
Edit: It's AIR sytem, bank one. That's a start. Depending on your emission testing I recommend ripping the AIR and EGR systems out and blocking off where they used to connect. Then have the codes tuned away.
Old 05-11-2005, 11:12 AM
2001NBMZ28's Avatar
Most likely a clogged driver's side air check valve, or the hose or pipe is leaking air. GM PN is 12565503
Old 05-11-2005, 11:40 AM
Do you guys know what the part looks like? And where it is so I could knock out of the way.
Old 05-11-2005, 12:09 PM
2001NBMZ28's Avatar
It's the black disc shaped valve between the air tube off the exhaust manifold and hose that snakes under the cowl - right above the #5 cyl coil pack. Easiest way to replace it is undo the hose side and remove the two air tube bolts so you can unscrew it while it's off the car. Mine was stuck on there pretty tight.
Old 05-11-2005, 12:27 PM
Thanks I know which one it is now?? Should I get a new hose or should I just clean it out?
Old 05-11-2005, 12:38 PM
2001NBMZ28's Avatar
My hose didn't look bad, I just replaced the valve. BTW, if you don't have something to clear the code, and don't want to reset your PCM, it's supposed to clear itself after 3 or 4 consecutive cold starts with no failures.
Old 05-11-2005, 12:49 PM
So just replace the black valve? Good Ill look into it. AutoZone??
Old 05-11-2005, 01:38 PM
2001NBMZ28's Avatar
Think I paid $15 at NAPA - dealer wanted double that - this was last summer.
Old 05-11-2005, 02:10 PM
Cool!!
Quick Reply: Threw a Code P1415. Can someone help me.
