Full Throttle Tuner?
Does anybody have the full throttle tuner from thunder racing?
I was curious as to what all it has built in. It has a WOT I believe, and an RPM "ON" switch. But does it have an RPM "OFF" switch? I didn't know if I could use this tuner as an RPM window switch as well?
I think it has first gear lock out also?
I emailed thunder racing but I never got a reply.
I'm finally getting around to pricing everything out and all these little accessories are adding up. I have an M6 so I need the RPM window switch, WOT...anything else I'm forgetting?
Restricted User
I have one sitting in my closet, with a new wiring harness and instructions. It does have a window switch built in (Min and Max settings), as well as timing retard(up to -12*)/advance settings(up to +7*), no 1st gear lock out sorry. As well, has a few other features, like activation delay(from no delay to .8 sec delay).
Hope that helps, and might be selling mine
Charlie (cat3) emailed me the directions for the timing tuner. Give me your email and I'll forward it to you. It does have an ON and OFF, but from what I understand from the directions the max off is like 5,900 or 6,300rpm. If that's true it's useless for a car with a cam. It does have a timed delay but not a 1st gear lockout. So if you hit it from a roll in any gear you'll still have the delay.
EDIT: missed Charlie's post.
