Newb questions - Help me out w/ my setup please! (TNT)
I currently have a cam only A4 01 SS w/ 3500 stall.
OK, here's what I've already got ordered (from another board member).
Complete TNT F1 kit w/ Power ring
TNT Purge
TPS
MSD Window switch
Planning on ordering:
Dynotune pressure sensitive bottle heater
Some type of switch plate (jimmy jam or NX)
I think I'll order a fuel pump to be on the safe side. I saw a holley 255 lph in-tank on thunder. Any reason to go with an in-line, or any other pump over this?
My lid is in kinda rough shape, is there any lid in particular I should buy to help w/ any fitment issues with the power ring, since I could use one anyway?
Shift points are at 6700, I was thinking of about 3800 & 6500 rpm pills. Sound good?
Is there any reason to get a FPSS w/ the bigger pump? The only reason I could see would be a total failure of the pump.
I was originally planning on spraying a 150 shot, but this would be more like a 175 shot with the TNT kit from what I've read. Does that sound like a little too much to anyone? I want to have a relatively safe setup, so maybe I should go with the 125 jets??
Car will be retuned by HPE in houston, and from what they've told me it will probably be 25 or 26 deg WOT timing. I will more than likely use some Torco or add some higher octane fuel to help avoid any detonation, I've never seen any w/ the current tune @ 27 deg, but want to be on the safe side when spraying.
I've never had a nitrous car before so if there is something important missing here, please bring it up.
Thanks in advance,
Craig
TNT Purge
TPS
MSD Window switch
Thanks in advance,
Craig
Definitely get a fuel pump, the 255 in-tank is better than the in-line.
For lids, I'm not really sure if there is one that fits best with the TNT kit, I have a TSP lid on my car and had to cut the lid quite a bit to get it to fit, but after some cutting with a dremel it fits great.
Shift points sound good to me. Someone correct me if I'm wrong, but you could even start spraying a little sooner than 3800 (unless you're doing it for traction reasons). I shift at 6600 and my window switch is currently set up for 3400 - 6400.
I recommend you get the FPSS just because it's cheap insurance. Then again, I'm one of those people that likes to use every possible safety item out tere .
As far as the TNT 150 shot being more like a 175, if you do a search on here you'll find one of the TNT techs talking about how many people tend to make more rwhp than advertized because they are running a leaner A/F ratio than what the kit was designed for. I *think* he mentioned something like the proper ratio was something like 12:1 on motor, then add the spray (I could be wrong, do a search to be sure).
Hope this helps!
Hope this helps!
