Where Should I put My LTFT Boundaries At with my HPT?
I am trying to tune my VE Table,Per HPT Directions.Now before I start logging what should I set my rpm range for High Mid and Low LTFT's?My Tuner has me at 900rpm 1400 rpm 2200rpm.Is this good or should I change it?Also for my High,mid and Low map.my tuner has me at 37 57 and 77 Thanks for the info...
Scott
Scott
Scott
Scott
Originally Posted by 405HP_Z06
Those are stock values for those two tables. Jimmyblue described this very well. From what I remember, he said that you want to set the values at even intervals to allow for greater resolution of the fueling tables.
Check out this thread. Jimmyblue talks about this in the last post.
https://ls1tech.com/forums/showthrea...highlight=ltft
Scott
