So what kind of power can get out of a single 98 intank racetronix?
I figured it would be good for ~550rwhp on a FI car. Curious what kind of rwhp people are seeing with these pumps. This new one in my car is running out at less then 500rwhp - I thought it would be enough but maybe not..
M6 I assume? No BAP and I'm at 10-11psi with ported heads, headers and a '01 Z06 cam. I cant imagine this making more then 550 (m6 rwhp), its probably ~500rw dynojet with the th400 at the most right now. Fuel pressure is dropping off hard after 5900rpm and I seen 15:1 a/f (I have 57lb injectors and from 70% to 99% duty cycle the a/f doesnt change at high rpm. Luckily I had 110 fuel and the timing dropped back.
I hate to invest in a BAP if it isnt enough, unless this is making more power then i think it is - hate to waste the time on the dyno knowing its running out of fuel though
I'm at 568 with my new set-up . Pressure drops to 44-45 at WOT running out of fuel at 5,000 rpm's with the 42 # svo's . Im going to take my tuner's advice and look into meth. really soon .
Originally Posted by onfire
T400 plus incon plus locked vig. What are you doing for a return line? I removed the stock regulator at the pump and installed a adjustable reg at the return line tee.
LS1TECH Sponsor
Originally Posted by kp
Still the stock rails/regulator. I'm just looking for around 525 unlocked and I thought this would do it. Maybe I'll try a BAP and see if that will get me enough if everything looks OK under the car.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
If you go with a FM FPR do you have to run a return line setup? I understand how the stock lines work with the FPR in the tank and the tee after the FPR but if you move it up front dont you have to run the return line after the FP?? I was going to do the EVAP/return line mod but my garage is going to stink like gas with no evap
http://www.harlan-engineering.com/incon/day3.html
The whole V6 line assembly was 50.00, the vent line was a little different so I kept my stock one and swapped the pressure and added the return line. Everything connects at the tank and filter perfect. I just took out the stock regulator and ran a hose to the sock like stock (98).
Makes for a nice clean install, the blue fitting is for the return, stock EVAP is hooked up so my garage wont stink. I am going to put an aeromotive compact EFI regulator on the RH front fuel rail and we'll see what happens. I upped my pulley so now I am at ~13psi of boost and with the regulator in the back and the BAP/racetronix its not keeping up at all.
If this doesnt work I'll get rid of the BAP/racetronix pump and do a dual 255 in the tank feeding the stock filter/lines. Should work fine with the regulator up front. The fuel deal on this car is really frustrating. My last ATI car had the stock pump + the little ATI inline and took 9psi and a 50 shot of nitrous with no problem on the stock lines/regulator
Its very possible this pump is bad as well, I got a lot of metal shavings out of the original and this second fuel filter when I emptied it - tank was flushed out before I installed the pump so I have no idea where all the metal is coming from.
