Ok try this again.. WHAT PILLS FOR 100-150 SHOT
I've got the Nitrous Oxide Systesm Universal Wet kit.. Its a damn good kit and it comes with the big solenoids good for a 300shot. Also comes with the stainless pills and a fogger A-nozzle. I'm trying to figure out exactly what size shot I've been spraying.
The pills are 55 on the nitrous and 33 on the gas if I remember correctly. I think that is right around a 125 shot but I'm not 100% sure. The instructions dont really tell which pills do what cause its a universal kit and it all depends on the fuel pressure that your car has.
So what size jets are you guys running with your wet kits from NOS?
those numbers just dont quite look right to me.. it said a 47 nitrous jet for a 100 shot. isnt that the same jet used in a dry kit for a 100 shot? i dont know, but are the nitrous jets the same in both a wet kit and a dry kit? cause i didnt think they were..
Originally Posted by Magic Chicken
Call the manufacturer, it's the easiest and fastest way to get the right answer for your manufacturers kit as they are all not the same.
Yeah I just talked to a friend of mine and he used that chart for his 5177 kit.. Looks like I've got the correct Nitrous jet in it but need to change the fuel jet. I've got the 33 in it and it says so use the 29. 33 is basically the fuel jet for a 150 shot.. But, I was tryin to be safe with the 33 jet to run it a lil rich cause the car had never been tuned at all.. Its been tuned now so I can go down a few sizes and see if it picks up..
I dyno'd the car Saturday and it only picked up 100rwhp on the spray..
12 Second Truck Club
NOS kits are rated at the flywheel not the wheels. 100 on a 125 shot is good with NOS. If you want a kit that puts out what it advertises, get a NX kit (or TNT).
Check out this neat jet calculator on Dyno Tune's site, http://www.speedshop.org/store/scrip...ousjetcalc.asp .
I bought a 30 fuel jet today.. I'll put it in this weekend and take her for a spin and see how it acts.. It should be ok.
I've never heard that NOS advertises flywheel numbers... And a few buddies that have the 5177 kit have the 100 shot jets in and they got anywhere from 95-105hp gain at the wheels.
I'll stick with NOS.. NX is good stuff, but I wouldnt trust a TNT kit.. Heard way to many bad things about them and their jetting.
So if I look up a NX 125 shots jet sizes and put that in my NOS kit then it will actually do 125 to the wheels? That doesnt make any sense..
The different manufacturers just use different jet sizes at there hp ratings. An nx kit doesn't make more hp than a nos kit with the same exact jet sizes installed. Nx's 150hp jets are just slightly bigger than nos's.
