built tranny
built tranny
I have to pull the tranny because the slave cyllinder is finished, and is leaking tranny fluid. I will be going with a 408 Iron block with a 300 direct port shot in the near future and i need advice on what to do.
Should i go with a new tranny altogether or just have this one built to handle the power? If you say go with a new one, what trannys(manual) should i consider. If you say build the t56, then what parts should i upgrade? I never want to have to worry about the tranny again, so i am looking to build a tranny that can handle the kinda power i am talking about
I would go through it and upgrade it( 3/4 fork, carbon-partile blockers and maybe some other parts) If you are leaking tranny fluid, it is not comming from the slave as it uses brake fluid( I hope thats what youhave in there)
