Removing Air, rear O2 and EGR....SES enable On or OFF
Old 05-17-2005, 01:35 PM
NufNuffZ28's Avatar
Default Removing Air, rear O2 and EGR....SES enable On or OFF
I have the rundown of what I need to turn off I believe, but what is a step by step to disable these in HPTuners?
Air removal:
Air on temp 255
remove fuse
codes 410, 412, 418, 415, 416
EGR removal
Off under Engine-----> general
Turn Off radio button to keep the extra timing OUT under part throttle
off codes 401, 402, 403, 404, 405, 406, 409
O2
remove codes
0134, 0138, 0140, 0141, 0157, 0158, 0160, 0161, 420, 460
Look correct?
Also, what is the best way to make these look ready when inspection time comes around as far as SES enable/disable and No Error reported when disabling.
Thanks
Chris
Old 05-17-2005, 01:45 PM
horist's Avatar
I usually set it to not set an error, but leave the SES on
Old 05-17-2005, 02:05 PM
NufNuffZ28's Avatar
Does everything else I stated look pretty much correct? I added what I have thus far, but have not changed all of the m yet and thus recieving an SES light again
So, does that make the SES light on all the time???
What does setting that to on or off actually do if the codes are disabled?
Thanks
Chris
Old 05-17-2005, 07:21 PM
soundengineer's Avatar
scan the code and see what code it is throwing...then change that code to "no error reported"
I changed all my rear o2 codes all my egr codes and all of mt seconday air injection codes to "no error reported" and I leave the SES on/off set to on...
otherwise everthing else looks correct to me
Quick Reply: Removing Air, rear O2 and EGR....SES enable On or OFF
