Air System Failure?
Old 05-17-2005, 10:00 PM
cordoyne's Avatar
Default Air System Failure?
My Camaro just through a code that says air systems failure. Anyone know what that might be?
Old 05-17-2005, 10:12 PM
horist's Avatar
what is the code? that'll tell you if it's driver side or pasenger side...
it's talking about the AIR pump setup for emissions... these are the tubes that go into each header/exhaust manifold. (if you have a 2000 or older then you'll have EGR also on passenger side along w/air)
Old 05-17-2005, 10:15 PM
cordoyne's Avatar
The code is 0410. I know the tubes your talking about are they leaking or somthing?
