Teflon Paste?
Old 05-18-2005, 06:34 PM
96KillaZ's Avatar
Default Teflon Paste?
My install intructions tell me to us is stuff, where do I get it?
Old 05-18-2005, 07:00 PM
ScottyG's Avatar
Any parts store will have it....
Old 05-18-2005, 07:24 PM
860 Performance's Avatar
Also, any good hardware store will most likely have it.
Old 05-18-2005, 08:37 PM
SLowETz's Avatar
FWIW... I use the ARP paste. Never an issue.
Old 05-18-2005, 09:41 PM
12 Second Truck Club
Magic Chicken's Avatar
The paste I've had experience with didn't make me too happy and it was a big name brand company's paste, won't use it again. It still hadn't dried after a month or so and was leaking. I'll stick with the tape, even though it "can clog your solenoids and nozzles." Put it on right and that won't be a problem.
Old 05-19-2005, 06:18 AM
ITLstallion04's Avatar
I used liquid teflon, and it worked great.
Old 05-19-2005, 08:48 AM
Closed ex-Sponsor Account
NXRICKY's Avatar
If teflon paste can not be found you can use red loctite. Just make sure when you put the parts together you tighten properly. Once dried its hard to retighten. Also when its time to pull the parts apart you will a little heat.
Ricky
Old 05-19-2005, 08:00 PM
96KillaZ's Avatar
I went to the auto part store today and couldnt find it, what name does it go by? If I still cant find it then I'll use lock tight, I already have the blue kind, Can I use that instead of the red
Old 05-19-2005, 08:18 PM
MetallicaMatt's Avatar
Ricky
instead of red loctite (which is pretty hard to get off) could you use the blue (i think its blue) or whatever color the less-permanent stuff is. would that work okay?
Old 05-19-2005, 08:38 PM
spootnik's Avatar
Go to a hardware store, its usually by all the natural gas/plumbing supplies right next to the tape.
Old 05-19-2005, 08:41 PM
Broken041's Avatar
They sell it in the tube or in the small jar with a under the lid.
Old 05-19-2005, 09:41 PM
01 Red WS6's Avatar
Thats what I would use
