Transgo Shift Kit installation problems
Anyone know where I can get a scan of the install instructions that come with the TransGo kit? I think we might have used the wrong spring/check ball for the 2-3 shift since I am almost 100% sure the transmission is shifting from 2nd straight to OD after the install. Anyone know where to order the assembly for the 2-3 shift (spring/check ball etc...) only?
TIA
TIA
Pontiacerator
With a converter and this kit, the 3-4 shift can be so subtle that it's almost unnoticeable ... in mild driving sometimes all I can notice is a slight drop in rpm. Many times it feels like two shifts + lockup. But it actually shifts 3 times. The shift is much more noticeable when you're driving hard.
