Whats the differance between 7.400 and 7.350 pushrods?
LS1 Tech Administrator
7.40 is stock length. It is ideal for stock cams and unmilled heads. Many aftermarket cams have a smaller base circle than stock, which in theory would require a longer pushrod, but most racers keep the stock length pushrod to allow the pushrod to work higher in the plunger of the roller lifter (this keeps the lifter from pumping up and extends rpm range).
7.35" pushrods are .050" shorter and work well when you've milled the heads .030" or more. The shorter length keeps the valve geometry closer to stock (which is close to ideal).
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Originally Posted by Patrick G
Pushrods or shims.
