Oil Pressure gauge maxed out...
Old 05-21-2005, 08:14 PM
slyws6's Avatar
Default Oil Pressure gauge maxed out...
...since the search button seems to be broken right now does anyone know why the oil pressure gauge would be maxed out? When I turn the key on all gauges go down to the left but the oil pressure gauge actually moves to the right and stays there. Also I just installed the new engine, checked all grounds and they seem fine. I have a spare sending unit I will put in but I thought I read on here before that this has happened and there was another cause....anyone know what it is??
-Sly
Old 05-21-2005, 08:31 PM
Red99TA's Avatar
I thought this was the result of a broken sending unit...wouldn't hurt to pop the new one in and see.
Old 05-21-2005, 08:33 PM
slyws6's Avatar
Cool that's what I was thinking but wanted to verify that there wasn't something else that could cause this. Thanks!
-Sly
Anyone know what size socket it is to remove it?
Old 05-21-2005, 08:38 PM
Red99TA's Avatar
Not sure but it's online somewhere. I do know you will need one deep-*** socket to get it off. I snapped mine and used a regular socket to get the base out and then hand-tightened the new one on until I could find a deep socket (I know...bad idea).
Quick Reply: Oil Pressure gauge maxed out...
