Bell housing
i forget how many there are, there is one way up top that you should check, with the engine leaning against the firewall you can feel it but you cant see it unless the tranny is out, other than that nothing else holds it stick a screw driver on it somewhere and bump it a lil, mine came right off
First time I had mine off (at 47k miles, to replace stock clutch), I had to beat the absolute **** out of my bellhousing to get it off. I removed the starter, put a 2x4 there, and started hammering. Pretty much destroyed the 2x4. I used anti-seize when I put it back together (after mildly sanding the dowels).
