9247 RPM's whats going on?
Old 05-24-2005, 02:41 PM
Mustang Hat'r 2's Avatar
Default 9247 RPM's whats going on?
Did some log files recently and got about 20 cells where I hit 9000+ rpms. The shift light has been coming on when I am around 3-4krpms. Is my clutch slipping for a split second and causing this? Help me out this has gotten me nervous.
Old 05-24-2005, 03:05 PM
HumpinSS's Avatar
what scanner are you using. Sounds like data errors. If your stock bottom end hit 9k
1. you would hear it
2. you would lose it
Old 05-24-2005, 04:18 PM
A-tap
My shift light is coming on too. Do you think it could be a loose wire?
Old 05-24-2005, 05:47 PM
Camaro ChriSS's Avatar
Hmm. I've had Atap show me doing 500 rpm and 30 mph faster than I'm sure I was doing one time on a data log. Only once though.
