ABS inop?
Old 05-28-2005, 10:19 AM
BoomerSooner's Avatar
Default ABS inop?
I dynoed my car last week, dynoed kinda low but it is untuned, but after I got out from the shop,my ABS inop light stayed on , so I got home , disconnected the battery to reset the ECM, light still stayed on, so I drove it, thinking it would correct itself, I panic stopped once, and locked them up, no ABS at all. is there anything I can do short of taking it to GM?
99 T/A M6
full bolt ons, stealth 2 cam
358hp, 340tq
Old 05-28-2005, 12:11 PM
slow's Avatar
if the ABS inop does not correct itself in a 100 yard drive, then the problem is with a sensor. Check the rear sensors to make sure none were unplugged, or damaged when the vehicle was on the dyno.
Ryan
Old 05-28-2005, 04:50 PM
oange ss's Avatar
wiring harness connector , driver's side by the rear axle,under the car ...happens all the time
