Quick PCM ?
Old 05-29-2005, 09:36 AM
lilbuddy1587's Avatar
Default Quick PCM ?
I had to recently pull my pcm to push it out of the way so that i could install my tach/shift light. After that was all said and done, my car threw an SES light. I havent checked it yet, but I was wondering if me pulling the pcm like i did and then putting it back in place after i was done hurt anything ?
Old 05-29-2005, 10:11 AM
2001NBMZ28's Avatar
I've removed mine a couple times without any problem. Did you disconnect the battery first? SES coming on might just be a coincidence - get that puppy read.
Old 05-29-2005, 06:41 PM
also, now that i messed with the pcm its hard to get into reverse as well. You have to like work it HARD. It's pissing me off
Old 05-30-2005, 04:57 PM
2001NBMZ28's Avatar
Just guessing without the code(s), but it's probably related. I'd check the ENG SEN fuse for the heck of it - it controls the reverse lockout and skip shift solenoids.
