Oil pump shimming??
Old 06-02-2005, 04:33 AM
fastbasser's Avatar
Default Oil pump shimming??
How much do you shim them to raise oil pressure 10-20 lbs? Is there a shim sold by a vendor? I couldn't find anthing with a search.
Thanks
Old 06-02-2005, 06:10 AM
StevieZ's Avatar
Thanks
.120" Just use a washer that is the correct diameter and thickness.
Old 06-02-2005, 12:25 PM
BigSteele's Avatar
do you put the shim behind the spring for the valve?
would this increase the pressure at all rpms or just increase it on low rpms, is this a common thing to do with the "ported" oil pumps
Old 06-02-2005, 01:18 PM
StevieZ's Avatar
Yes, you put it behind the spring (shim then spring then allen bolt) and it will increase the pressure at all levels.
Old 06-02-2005, 03:59 PM
BigSteele's Avatar
so if you just buy a stock LS6 oil pump, you can add a shim to increase its pressure in all rpm ranges, why dosent everyone do this?
would adding a shim cause any neg. effects? does the valve just regulate/release pressure
