Worst that can happen with TDC valve spring swap
So if I'm off a cycle and the piston is down in the cylinder will the vavle drop enough that I need to take the head off to retrieve... or can I just hold the vavle up by hand and turn over the motor to bring it back up to put the spring on??
I am thinking of doing the springs this weekend and the cam next weekend so It would be easy if I could use the cam dot as reference but I won't have the front of the car off to do that....
Thanks!
Thanks!
Much easier to put the cam first. With cover off and dot to dot, #1 and #6 at TDC change those, then follow the sequence by rotating clockwise 90* at a time.
Http://www.ls1howto.com
