can you change front main seal w/o removing timing cover
did a cam swap for a buddy today and he didnt get a new front main seal so we reused the one he had.
needless to say we button it up and it has a very slow oil leak out of it only when its running
so we need to change the front main seal, can you do it without removing the timing cover, cause i would really like to avoid draining the radiator and taking off the water pump again if possible
everytime ive done a swap like this (like 10-12) i always put the new seal in than loosely screw in all the bolts to the timing cover when installing it and install the pulley so the pulley is centered in the seal, than i tighten all the bolts to the cover. this has always helped avoid leaks like this
if i just yank the old seal out and put in the new one i wont be able to do this. do you think this will be a problem??
be EXTREMELY CAREFUL when installing the new seal. That ALUMINUM cover is very thin! Without support from behind, you run a good chance of tweaking the cover or breaking the retainer lip on the inside of the cover.
