ne thoughts on the jegs performance gear kit?
looks like it has everything i need to install my 4.10's and replace stuff that needs replacing..
"We have combined our high quality heat treated gear sets with a Richmond Gear complete installation kit, two quarts of Red Line 80W140 differential lube and a 4oz. bottle of Jeg's own limited slip additive. Each installation kit includes pinion and carrier bearings, pinion and carrier shims, pinion nut, crush sleeve, pinion seal, cover gasket, gasket sealer, ring gear bolts, thread locker sealant, marking compound and installation instructions:"
i can get it with jeggs gears for 298$ or with richmonds for 321$... i bet there prolly the same exact gear.
