Tranny Install problems
Can anyone help??
I am trying to install the driveshaft but the end that goes into the tail end of the trans will not go in all the way what should I do..???????????
did you use the instal tool to align the friction disk, does it go far in, so the instal tool goes into the pilot bearing in the back. put some grease on the shaft and you just have to push and wiggle it in
