5.3 to 5.7 tune
Old 06-04-2005, 10:20 PM
Rob'sGMCSS's Avatar
Default 5.3 to 5.7 tune
I have a 02 GMC Sierra RCSB. It had a 5.3L but I swapped it out for a 5.7 out of a 02 Vette. The truck runs good, but I know theres alot more power under that hood. Would a tune wake this truck up? what do you guys think.
Old 06-04-2005, 10:39 PM
87GMC's Avatar
Timing for starters, second a little ve tuning. Did you use the injectors off of the 5.7 or the 5.3?
Old 06-04-2005, 11:46 PM
horist's Avatar
^^^ ditto..
what injectors are you using?
what MAF ar you using?
if you're running 28lb/hr injectors and a stock C5 MAF ... there are lots of bins on my site (stickied above) that you can flash over
Old 06-05-2005, 11:18 AM
Rob'sGMCSS's Avatar
I used the 5.3 injectors and the 5.3 maf, If I swap out injectors will it help out. I did take the screen out of the maf. what do you guys recommend I do. thanks.
