FI to carb afpr question
Since my 3800 swap refuses to start ever since I got back from deployment(stupid fuel enable signal crap) I got a hookup for a (87)305/700R4* swap in teh works, plus everything I need from the donor car. I've researched and have read about teh mallory afpr for ~$75. It is a bypass type regulator. What is the difference between that and getting a 2port regular and using the second port for the return line?
* why go w/a305? the price is too reasonable to refuse, and once the swap is done, a bigger upgrade is soo much easier
thanks
thanks
The two port is presurized on both sides. A friend of mine is using the two port holley on his car with one line as the bypass and so far it is working. I don't know how well it will work in the long term with the stock 2.8 tbi pump.
Should work fine. Mine lasted more than a year and roughly 5000 miles. Stock TPI pump regulated down to 7-8psi. I just went to the Aeromotive which comes with a low and high pressure spring setup. I don't see why the Mallory would be different in terms of handling pressure or wearing out in any way. Goodluck! A carb 305 can be tons of fun, especially when you do a plate kit and spray away.
