installed a 3500 TCI and WOW!!!
Old 06-10-2005, 10:33 PM
seadoo's Avatar
Default installed a 3500 TCI and WOW!!!
I love this thing... it a stop it will burn 'um for 100 ft. but, I thought that if you floor it from like 30 it will just blow the tires, mine doesnt. I run a pretty soft set of kumhos and it will spin for a second or two them jump like a bat out of hell. do i just have good tires, or is there something wrong? and all i have adjusted is the shift timing and pressure.. the thing locks at 36mph with stock table what else do I need to adjust? and lockup durning a run at the track with this stall and stock tables?
thanks
Old 06-10-2005, 10:45 PM
blue2000Z28's Avatar
Glad you like it, i ordered a Vig 4000 so i hope i will be just as happy
Old 06-11-2005, 02:06 AM
Raptor99's Avatar
If you've got a decent set of tires, it should only spin for a sec or two if you hit it from 20-30. That's all mine does, and I have 275 Nitto street tires in the back with a healthy set of mods.
Glad you like the stall. You might also want to look into getting TM deleting if you haven't yet.
Old 06-11-2005, 08:16 AM
RedHardSupra's Avatar
for a stall like that, use jimmyblue settings, they're real good.
Old 06-11-2005, 09:56 AM
seadoo's Avatar
thanks man which of the tables... I have the base shift pressure at 90 then going up to 96 at 95% max line pressure, and 1.0 shift timing. and I have 3.23's and he has 3.42's.
just trying to learn, thanks man
