How much to mill heads.. please help!!
I am currently doing a 6.0L conversion in my 98 TA, I am using a stock 6.0L Iron block out of a 01 Silverado and am using stock LS1 heads [kind of on a budget. My question is, How much would I need to mill the 5.7 heads to reach 10.5:1 compression with the dished piston on the 6.0L block. I do not know the cc on the pistons but everything is stock, can someone please help me out??
you are better off finding LQ9 heads and mill those.
Not only does the 6.0 have a bigger bore, but the LS1 heads will flow less. LQ ( heads have the same runners as LS6)
