Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Sbc Bolt Sizes Anyone???
Old 06-15-2005, 12:04 AM
Strokinit383's Avatar
Default Sbc Bolt Sizes Anyone???
Does anyone know or have a link to all the bolt sizes for a small block chevy?
I know the harmonic damper is 7/16 - 20 x 2.25 and the cam bolts are 5/16 - 18 x 3/4 and the exhaust manifold bolts are 3/8 - 16 x 3/4.
Anyone know the sizes of the 3 different head bolts, main bolts 4 or 2 bolt, oil pan bolts, oil pump bolt (I think this one is 7/16 - 14 x 2.25 but im not sure), intake manifold, valve cover, thermostat housing, distributor, timing cover, water pump, all accessories (alternator, pulleys, etc.)
I think this would be very helpful to anyone building a sbc. Too late ive already bought all of my bolts in a kit or i wouldve definitely taken advantage of this. I guess it would be easiest to just start a running list.
Harmonic damper = 7/16 - 20 x 2.25
Cam bolts = 5/16 - 18 x 3/4
Exhaust manifold bolts = 3/8 - 16 x 3/4
Oil pump = 7/16 - 14 x 2.25
Old 06-15-2005, 02:50 AM
terr1bleone's Avatar
your going to need a few more sizes, 5/8, 9/16, 1/2 and those are all the sizes i needed to build my motor.
Old 06-15-2005, 09:38 AM
oil pan, valve covers, and timing cover = 1/4-20x3/4
oil pan also has four 5/16-18x3/4
intake manifold = 3/8-16x1.25
Old 06-15-2005, 05:38 PM
What??? That didnt make any sense.
Old 06-16-2005, 12:26 AM
yeah, all the sizes that you listed, plus parts like the rocker arms 5/8, distributer 9/16, and carb 1/2. there arent any set sizes for sbc bolts, my headbolts, rocker arms, balancer, and waterpump/filler neck are 5/8, my intake manifold, dist, and misc accessories are 9/16. take for example your exhuast manifolds are 3/8. mine are 7/16.
Old 06-16-2005, 02:50 AM
twoduners11's Avatar
not to be a smart ***, but the sizes your reffering to are the fractions printed on your WRENCH not the actual size of the fastner. but seriously go to your local hardware store w/ a few of your wrenches and spend some time in the bolt bins. its actually fun to learn. and a whole new world will open up for ya
have fun
mark
Old 06-16-2005, 12:57 PM
have fun
mark
yeah, i wasnt even paying attention. i thought this was about what wrenches you would need to build a motor. sorry.
Old 06-16-2005, 01:02 PM
What i have so far:
Coil Bracket:5/16-18 x 9/16
Distributor Hold-down:3/8-16 x 1/2
Fuel Pump:3/8-16 x 1 1/4
Fuel Pump Plate:1/4-20 x 1/2
Intake:3/8-16 x 1.25
Motor Mounts:3/8-16 x 3/4
Oil Pan:1/4-20 x 1/2, 5/16-18 x 9/16 (or 5/16-18 x ¾)
Timing cover:1/4-20 x 1/2
Valve Covers (perimeter):1/4-20 x 1/2
Water Neck:3/8-16 x 1, 3/8-16 x 2
Water Pump:3/8-16 x 2, 3/8-16 x 2 ½
Header bolts = 3/8 - 16 x 3/4
Old 07-08-2011, 12:11 AM
BSR29ss's Avatar
Default Carb bolts
I was wondering if you guys have bolt sizes for a Holley 4412, 1 inch spacer onto a 1979 SBC 350?
5/16-18 x ???
Quick Reply: Sbc Bolt Sizes Anyone???
