New LS1 Owners - Newbie Tech - Request Part Numbers
Pages : 1 2 [3]
View Full Version : Request Part Numbers
WS6Jayson
09-01-2007, 01:15 PM
I need the part number for a passenger side headlight motor. Thanks!
gonzo 6.0
09-06-2007, 12:56 PM
I thought I had seen a GM PN for the 3 wire connector for the 98Fbody coolant sensor,I cant find it and no luck with the search. Thanks
sensor # is 12551708
I need the connector # please.
rayhawk
09-19-2007, 04:57 PM
I can't find the part number for the main drive idler pulley. Am I missing something? Please help
LS1tones
09-24-2007, 07:49 AM
need part number for the turn signal fixtures, both left and right (pieces that hold the turn signal bulbs that clip into the turn signal housing) They have 3 wire inputs and hold the large bulb (not the parking light bulb).
My originals were replaced with bad non OEM replacements that dont seal around the signal housing and leak water into the housing.
Paul Bell
09-24-2007, 08:45 AM
That would be ACDELCO Part # LS54 OR GM part number 12159662
HoLLo
10-02-2007, 08:40 PM
I need the Coolant Temperature SENDER for a 97 LT1, the one with one wire, that goes to the gauge
HoLLo
10-28-2007, 11:24 AM
Also, what about the grill inserts for a 93-97 WS6 hood?
Malicious
11-02-2007, 01:48 PM
Looking for the part # for the front fender grills for a 98+ TA... Thanks!
Ackattack1
11-02-2007, 03:03 PM
Looking for part numbers for the coolant crossover tube, block off plates, gaskets, and bolts for a 2005 5.3L (silverado)
also, coolant temp sensor that goes in the drivers head
4bangermustang
11-04-2007, 12:10 AM
Looking for the part number of the CLIPS that attack to the WS6 hood where the screws go to hold in the grills in the hood.
Also need the clips that hold on plate where the TCS button is.
whiteseven
11-25-2007, 05:54 PM
What is the part number for the cover that goes around the starter to cover up the flywheel on the engine side of the transmission bell housing?
jmdale1984
12-07-2007, 01:10 AM
I couldn't find the part numbers for an LS1 starter, alternator or rocker arm. Maybe I missed it.
jmdale1984
12-07-2007, 01:17 AM
There is a new PN for the LS1 power steering pump.
26086074 should replace 26068936
jmdale1984
12-12-2007, 03:39 PM
Manual Transmission LS1 Y-Pipe Bracket PN 10284835 has been discontinued
camaroguy_02
12-14-2007, 10:22 AM
need the gear selector indicator plastic piece for an '02 z28 A4 pls
SpdFrk1990
01-08-2008, 07:52 PM
I need the part numbers for 98-02 camaro front bumper cover and the LH fender.
Thanks,
John
Wsteun
01-12-2008, 12:44 AM
Need the part # for the 98-02 SS hood insert.
Thanks.
Wsteun
01-12-2008, 08:47 AM
I also need the driver side rubber weather strip that runs on the top of the door.
MM98
01-12-2008, 08:56 AM
part of upper console plate, #10413134
fender#10419546
frt fascia#12335525
#12369964
MM98
01-12-2008, 08:58 AM
I also need the driver side rubber weather strip that runs on the top of the door.#10284223
Wsteun
01-12-2008, 08:08 PM
Got another part.
The little rubber/plastic piece that's on both sides of the engine bay in the front. It's height adjustable and raises/lowers the height of the hood.
MM98
01-14-2008, 06:37 PM
Got another part.
The little rubber/plastic piece that's on both sides of the engine bay in the front. It's height adjustable and raises/lowers the height of the hood.#10413888
SpdFrk1990
01-19-2008, 04:05 PM
Anyone know the part numbers for the heat shield over the muffler and the one that goes over the axle or all the ones underneath if you have the numbers.
Thanks,
John
MM98
01-21-2008, 12:05 PM
Thanks,
John
Muffler shield # 10239715- availiable
Over axle shield # 10408723- discontinued
Passenger side frt cat shield# 10417743- discontinued
SpdFrk1990
01-21-2008, 02:15 PM
Thanks
lilbuddy1587
01-31-2008, 10:13 AM
Can someone please tell me the part number for the Oil pan to rear cover bolts (long, skinny m6x1.0 bolts) ? Thanks!
MM98
01-31-2008, 03:55 PM
^ Part# 12554990
SpdFrk1990
03-05-2008, 12:07 PM
I need the part number for the driver side bracket that attaches to the headlight and the fog light.
817Borla
03-05-2008, 10:57 PM
whats the part number for 98-02 trans am front bumper cover
MM98
03-10-2008, 05:05 PM
^^ Part#12335523
ThunderZ28
03-14-2008, 08:04 AM
I need the part number for the adjustable bracket for the driver side headlamp.
the one that bolts to the headlamp, and slides onto the headlamp bracket.
ls1owner4life
03-19-2008, 03:33 PM
What is the name of the rear "CAMARO" panel between the bumper cover and rear hatch for a 98+? aka berger
blk/slvr02ss
03-19-2008, 05:32 PM
Filler panel.
ls1owner4life
03-20-2008, 12:38 AM
Filler panel.
All I found were pontiac tail filler panel part numbers...
zman1969
03-31-2008, 09:52 AM
how about part # for t/signal/daytime running lamp assy guess mine are leaking causing bulbs/sockets to burn up/corrode too easy - looking for lamp assy for Trans ams , allready found # for sockets and bulbs on the list
nice design GM :bang:
Dave 96TA
04-01-2008, 06:12 PM
PCV hoses on both sides of PCV valve - 99 Z28.
deejaydaze
04-05-2008, 12:05 PM
I'm looking for the passenger side power window switch bracket. I'm sure this has come up before. Does anyone know the part 3 and if it comes with the 2 clips? I found 10402841 on here but that just says...
Camaro power window switch (94-96), RH = 10402837
Camaro power window switch (2 switches in one unit) (94-96), LH = 10402838
Camaro power window switch (97-02), RH = 10402841
Camaro power window switch (2 switches in one unit) (97-02), LH = 10402842
I got 10288873 from the dealer just now and I don't think that is right. I can't find that part number anywhere.
I don't need the switches, just need the bracket part.
Kevin01Z28
04-14-2008, 06:36 PM
Ive done multiple searches and came up with 12571261 which is for 98-02 ls1's but its a 195*. Owner's manual for 01-02s says the 5.7 has a 180. I cant comfirm this. Trying to decide to go with 160 or not. If it does in fact have the 180 than i can get the money back for my slp 160 stat.
Blksilvr
04-14-2008, 08:05 PM
Need part # for a 2000 trans am M6
Tail Extension housing GM
Vent Tube, GM
Housing, Clutch Adapter GM
Transmission Front Adapter (GM)
wtomlinson
04-24-2008, 12:44 AM
need part # 2001 Z-28 A4
bend bracket that holds the bumper and the front fascia together. has the 3 built-in screws on the bottom. drivers side
98boxer
04-29-2008, 03:18 PM
I didn't see a "tan" seat belt guide number heres the one i got from the dealer for the
Driver side #16789715
98boxer
04-29-2008, 03:25 PM
Here's also the part number to the front passenger seat "caps" for the bolts that hold down the front passenger seat.
Passenger bolt "caps" #16718899
Shatterz
05-01-2008, 08:39 AM
I need a part # for a 2002 Z28 M6
- Shifter isolator cup (piece that shifter ball fits into t-56 transmission)
Here's a pic
http://i28.photobucket.com/albums/c219/vmrchevy/shifterisolator.jpg
spike30th
05-08-2008, 12:43 AM
I need the part number for a equalizer. its part of the parking brake where the rear 2 cables attach to the front 1.thanks
C Murda
05-08-2008, 09:28 AM
i need the part number for a 2002 LS1 power steering rack&pinion. ive gotten so many different part numbers and my very own 02 Z28 has a part number of 26048277 which is different from the part number posted on that list of 26062311? also i tried entering my part number on GM parts direct and i got nothing? what is up?
aothepresident
05-09-2008, 10:46 AM
I need the part number for the plastic piece that goes around the handle and lock on the driver's side. It also holds the piece with the power window, mirror, and lock controls. Not sure what to call it exactly. It's for a 2000 Z28. Any help would be appreciated, thanks.
FourFourTwo
05-16-2008, 10:15 PM
LS1/LS6 coolant pipe (01-02) (need for installing LS6 intake manifold) = 12568478
LS1/LS6 coolant plug (01-02) (need 2) (need for installing LS6 intake manifold) = 12562788
Anyone have the new part numbers for these?
ghettocruiser
05-20-2008, 08:12 AM
Does a part number exist for the bushing in the clutch master cylinder rod??? I dont know if something separate like that is available. Im doing something somewhat custom, so if anyone knows, let me know!
J.
waltonscott
06-04-2008, 07:06 AM
1999 WS6, need a part # for this...thanks
http://img59.imageshack.us/img59/9220/powersteeringjpgor7.jpg
Darksolder
06-10-2008, 10:06 AM
I want to make sure, that THIS: window outer sealing strip (93-02), RH = 10284222 is the weather strip thats out side of the window, keeps popping off, and i broke a few of the clips trying to fix it, and unless any one here has tips to install it, i'll have a garage install it.
Also, i need a clip for the window/door lock switch holder thing for it to clip to the door panel, will i just have to buy a new switch thing?
69LT1Bird
06-10-2008, 10:51 AM
26048589 HOSE, P/S GR OTLT F(LS1)(EXC V12)
69LT1Bird
06-10-2008, 10:57 AM
LS1/LS6 coolant pipe (01-02) (need for installing LS6 intake manifold) = 12568478 replaced by 12602544
LS1/LS6 coolant plug (01-02) (need 2) (need for installing LS6 intake manifold) = 12562788 replaced by 12602540
69LT1Bird
06-10-2008, 11:15 AM
26062311 is the part for your car. When you say "your" number, if that is the number stamped or molded into the part? If so, ignore it, that is a production part number and has been changed and superceded a long time ago.
69LT1Bird
06-10-2008, 11:20 AM
The cup is not serviced by itself, it is part of the offset shift lever, pn 12523298.
Here's a pic
69LT1Bird
06-10-2008, 11:25 AM
It is part of the front cable, pn 10258235, not serviced seperately.
69LT1Bird
06-10-2008, 11:34 AM
It gets even more confusing looking at the specs. The t-stat in that part numbered housing is designed to start opening at 186.5*f and full open at 212*f.
richdalenta
06-23-2008, 05:21 PM
For 2002 Firebird TA Ebony Leather Interior AQ9 (adj lumbar & side) seats
1. Plastic seatbacks (back cover, solid unpainted plastic, LH & RH - the part that have the nets)
2. LH drivers side seat bottom control panel (1 6-way switch, 2 rockers)
3. RH passengers side seat bottom control panel (2 rockers)
Note: do # 2 & 3 come in the correct color (ebony) or do you have to paint them? Thanks.
C Murda
07-04-2008, 12:35 PM
so is that actuall part number any where at all on the steering rack? if so where is it located i just want to check a few racks out and make sure i got the right one...
69LT1Bird
07-04-2008, 02:50 PM
If there is a number on the rack it can be pretty hard to cross reference back. Some times its a good number, other times it not. Once a part starts changing service part numbers it can get pretty confusing.
jaguar5822
07-07-2008, 02:42 PM
I need to know what these came off of, as far as year, trim level, ss.
Delphi-made in USA 01100912 22199128 M48, it's a front, and have a yellow tag on the spring, all I can make out is that it says ABS, and the 2 second to the last numbers are 22
deCarbon- made in France FRONT 3300 0 BN, also front, has yellow tag on spring 22077190
rear spring- all I can make out is **077420
Thank you very much ahead of time.
James
69LT1Bird
07-08-2008, 07:03 AM
None of the parts show anything specific for the SS. You would need to match the two letter codes to see if they are the same as your vehicle.
The hardest part is, over time the codes in the system get superceded and will not match what the older car may have on it.
22199128 - front shock absorber, 1993-2002 F car all models
22077190 - originally a 1994 part code FYJ, replaced several times after that with new numbers
22077420 - 1995 rear spring - newest part number will service 1982-2002, nothing special shown for usage.
ReD715
08-13-2008, 05:48 PM
A 98 A4 engine harness?
69LT1Bird
08-14-2008, 06:49 AM
12177560 F 5.7g(ls1), 4-spd A/trans(m30), A/c Man Cont(c60) Harness, Eng Wrg 1998-1998
FirebirdFlyboy
09-12-2008, 01:09 PM
I looked and looked but couldn't find it...
I need the part number for the wiring connector that connects to the electric window motors. Somehow the one on my drivers side window motor in my `99 SS is cracked and loose, causing my window to die intermittently.
InsaneAuto86
09-17-2008, 09:21 AM
p/n for the clear gauge bezel (? - the clear plastic cover that goes over the instrument cluster) for a 1995 camaro
69LT1Bird
09-17-2008, 09:28 AM
16131492 - $31.39 dealer list price, just shop around for the best price
69LT1Bird
09-17-2008, 09:34 AM
PN 12102779
InsaneAuto86
09-17-2008, 09:54 AM
THANKS!
FirebirdFlyboy
09-17-2008, 05:51 PM
PN 12102779
Thanks much! You're a gentleman and a scholar.
Don't worry... I won't tell anyone. ;)
Adam2001WS6
09-20-2008, 08:42 AM
Are the plastic "covers" that cover the bolt that holds the windshield wiper on a part of the entire windshield wiper assembly or can they be purchased separately? If they can be purchased separately, what's the P/N?
Thanks,
Adam
Blue2KTA
09-20-2008, 03:56 PM
Looking for the part number of the drivers side sun visor for Taupe (tan) interior.
Thanks
69LT1Bird
09-20-2008, 04:45 PM
Thanks
How about some more information like what kind of car, year, trim code, ya know, the important stuff for looking up parts.
Blue2KTA
09-20-2008, 07:09 PM
2000 Trans Am, don't know the trim code
Ntimid8r7
09-21-2008, 03:04 PM
corvette xm antenna? late C5 or C6 I am guessing?
69LT1Bird
09-22-2008, 09:35 AM
Thanks,
Adam
22155370 left arm
22155371 right arm
69LT1Bird
09-22-2008, 09:41 AM
Double check the RPO label, your trim code should be 52I, light neutral. They only list neutral and ebody.
10326252 right side
10326253 left side
In the future, if you do not know the codes or other info, your VIN will be needed, there are too many different options and combinations involved in looking up parts.
69LT1Bird
09-22-2008, 09:46 AM
So which is it? Different generations of cars. If you want to get the right answer get more information. If you walk into a dealer or any parts department with that request they will just laugh and blow you off. Not trying to be a jerk but I like to help you guys out but when you need a part you have to provide some level of detail to get the right part.
Ntimid8r7
09-22-2008, 10:35 AM
I figured they would be the same. C6 then................* EDIT*
Actually, dont bother. All that had to be said was there is a difference instead of the Monday morning rant. Thanks anyway.
Blue2KTA
09-22-2008, 11:35 AM
Thanks
Do you need any other info ?
69LT1Bird
09-22-2008, 12:27 PM
Look at post #577
Blue2KTA
09-22-2008, 05:05 PM
Look at post #577
I do have 52I on the RPO sticker, i guess thats it.
Thanks
69LT1Bird
09-22-2008, 05:46 PM
yep, that's you, colors are always a pain to decipher. That's why the codes are code necessary.
Adam2001WS6
09-25-2008, 04:39 PM
22155370 left arm
22155371 right arm
I looked at that, however, the cover doesn't look anything like it does when you look at the illusration of that part. :confused:
69LT1Bird
09-25-2008, 05:54 PM
Sometimes illustrations are generic, they depict the part but it may not look exactly like yours.
Adam2001WS6
09-26-2008, 12:06 PM
So that IS just the plastic bolt cover then? I'm so cautious when ordering parts online bc i've had some terrible luck with brakes that i'm currently in the middle of dealing with the huge screw up due to sellers messing up. Thanks.
69LT1Bird
09-26-2008, 01:05 PM
Go to the dealer and order them, $6.58 dealer list price each.
Droptoplt1ta
10-02-2008, 09:09 AM
Part # for:
1998 Camaro automatic A4 center console shifter plate (whole top piece)
Thanks!
69LT1Bird
10-02-2008, 10:27 AM
Part # for:
Thanks!
10297907
Droptoplt1ta
10-03-2008, 07:16 AM
10297907
Im sorry, is that part for a V6 or LS1?
I need the part # for a LS1
Thanks again
69LT1Bird
10-03-2008, 07:37 AM
This is the LS1 plate
10297907
C 1998 1998 Y 1 F FA 00 01
LS1 UC
USAGE: M30, GU2, GU5 (EXC TR7)
DESC.: PLATE,F/FLR CNSL TRANS SHFT OPG TR(REQUIRES NEW C/LTR CONNECTOR 15*
lauren
10-11-2008, 04:33 AM
haha I laughed when I saw how old this is, but it doesnt mean that another get together cant happen. Can get the list from the dealer as there are new parts now.
mike2008
10-16-2008, 03:22 AM
I got some of those from things other people had posted, as a shortcut to get the ones people liked to ask about, and checked a lot but not all of them...
I suspect that was on an older list that only covered LT1s but didn't specify the items were for LT1s, then someone posted it mixed in with a bunch of LS1 stuff, and I overlooked the mixup.
Thanks.
__________________________________________________ __________________
mike
digital backs (http://www.digitaltransitions.com) family dentistry raleigh (http://www.raleighdentist.com)
importkiller_SS
11-26-2008, 08:52 AM
i cant find the part #'s for a right side rocker panel
and for a 1998 camaro z28 coupe fiberglass rooftoping.
could anyone tell me what those #'s are?
69LT1Bird
11-26-2008, 09:10 AM
I am guessing you want the rocker sheetmetal, if so, here is that number:
Rt outer rocker panel - 12529163
I am not sure what a rooftoping is, please explain.
z28pat
12-10-2008, 10:14 AM
I'm looking for the front speaker grill/cover for the driver's side for an 02 camaro with the monsoon stereo.
I even looked on ebay for a used one!
thank you
pat
Adam2001WS6
12-11-2008, 12:15 AM
2001 Pont. T/A WS6
I need to know the P/N for the adjuster nut and adjuster screw for the rear hubs that actuate the parking brake shoes... Thanks.
71-Camaro-98
12-27-2008, 08:23 PM
I have tried doing a search but I am not coming up with anything... I need the part and casting numbers for the ls7 heads, thanks...
94-lt1
01-03-2009, 12:35 AM
anybody no the part number for a pwm tcc solenoid
blk/slvr02ss
01-12-2009, 04:22 PM
PCV Valve.
CRAZY21282
01-21-2009, 08:56 AM
pcv valve.
12590632
devilsalmostfree
02-05-2009, 06:33 PM
how bout the yoke for the t-56, 99 model if thats needed!
mook99ta
02-16-2009, 08:08 PM
White plastic clip on LS1 that retains fuel line for EVAP (I BELIEVE) on the intake manifold? Its on the left side of intake when looking at it from the drivers seat.
VinnyV
02-28-2009, 07:51 PM
I wanted to dress my engine up like the gmmg cars, which includes a carbon fiber air lid. I can't figure out the part # for the coolant decal installed to the right of the air lid / It's not the same as the one on my air lid, it's a little smaller. Can you help?
CAMARO PERFORMER
03-01-2009, 09:10 PM
I was looking for a pushrod and needed the part number
factory 99 camaro ls1 just need a single one..thnks
CRAZY21282
03-18-2009, 07:54 AM
10238852
miro
03-20-2009, 11:29 AM
I need the part number for the LS1 oil deflector nuts (windage tray nuts).
I could probably just go to the hardware store for these, but thought I might as well get the right ones since I'm about to order a lot of GM stuff. Can't find the part number anywhere though. GM dealer is useless.
Edit:
Nevermind. John from Scoggin-Dickey found it for me. It's PN 11517031.
nrs2420
03-23-2009, 10:18 PM
I need the part number for the LS1 power steering pressure hose and the return hose without the power steering cooler.
Thank You
thunder0880
03-24-2009, 09:15 AM
need the part # for the ls1 transmission tube.
airpower326
03-24-2009, 09:41 PM
Could I get the part number for an 02 trans am wiper arm assembly
ls1 dudes girl
03-25-2009, 12:11 AM
249,987 transam 2002.
Blue2KTA
04-04-2009, 05:20 PM
I'm looking for the latest part # for the rear brake pads kit for a 2000 Trans Am WS6.
Thanks
evilz
04-18-2009, 09:07 PM
ls1 lifter trays?
MIDNITE Z
04-20-2009, 01:12 AM
Need part number for 1998 camaro AC fan belt
Michael02hawk
04-20-2009, 10:54 AM
Under the hood there are two fuse boxes and labels.
FRC2 which lilsts the Fuel Pump is 15305530
FRC1 which lists the 3 Fans, I read to be 15305524
...but that number does not come up at the dealer nor at the online GM parts.
Can someone find out what the FRC1 fuse box label number is???
Thanks
JRocket
04-25-2009, 02:21 PM
01 F-body coil pack wiring harness(both sides).
Valve cover bolts and grommets for same motor.
I need to order these parts soon.
Thanks!
some_punk
04-29-2009, 10:01 PM
Does anybody have the part number for the tow hook that was available for the european market firebirds and camaros?
dynodanmanda79
05-03-2009, 12:31 PM
Do you have the part number for the LS1 F-body harmonic balancer? and also the engine service lift bracket part numbers?
Thanks, Dan
slayerized6
05-23-2009, 11:37 PM
clock spring for 98 t/a
98trans am
06-02-2009, 12:22 PM
could i get the part numbers for the seat belt guide on the passenger side (the triangle with a hole in it attached to the headrest) and the plastic cover for the bottom, side of driver's side seat (the one with the seat adjustment buttons on it)?
slayerized6
06-02-2009, 12:38 PM
front seat shoulder belt guide (93-96 coupe), graphite, RH = 16730218
front seat shoulder belt guide (93-96 coupe), graphite, LH = 16730219
front seat shoulder belt guide (93-96 coupe), gray, RH = 16730220
front seat shoulder belt guide (93-96 coupe), gray, LH = 16730221
front seat shoulder belt guide (93-96 coupe), beige, RH = 16730222
front seat shoulder belt guide (93-96 coupe), beige, LH = 16730223
front seat shoulder belt guide (96-02 coupe), neutral, RH = 16789714
front seat shoulder belt guide (96-02 coupe), neutral, LH = 16789715
front seat shoulder belt guide (97-99 coupe), gray, RH = 16799272
front seat shoulder belt guide (97-99 coupe), gray, LH = 16799273
front seat shoulder belt guide (97-02 coupe), pewter, RH = 16799274
front seat shoulder belt guide (97-02 coupe), pewter, LH = 16799275
front seat shoulder belt guide (00-02 coupe), ebony, RH = 16817200
front seat shoulder belt guide (00-02 coupe), ebony, LH = 16817201
front seat shoulder belt guide (97-99 convertible), gray, RH = 16799316
front seat shoulder belt guide (97-99 convertible), gray, LH = 16799317
front seat shoulder belt guide (96-02 convertible), neutral, RH = 16799318
front seat shoulder belt guide (96-02 convertible), neutral, LH = 16799319
front seat shoulder belt guide (97-02 convertible), pewter, RH = 16799320
front seat shoulder belt guide (97-02 convertible), pewter, LH = 16799321
front seat shoulder belt guide (00-02 convertible), ebony, RH = 16817202
front seat shoulder belt guide (00-02 convertible), ebony, LH = 16817203
http://www.ls1tech.com/forums/3064669-post24.html
Rhode Island Red
06-22-2009, 08:49 AM
My stock jack went kaput and I'm about to drive across country ... Need the part number for the jack...
Need the part number for the rubber bumber for the drivers side wiper blade (may as well give the pass side # as well) - you know, the rubber thing that the wiper arms rests on ... they pop out too easy (for a TA)
67turboduece
06-24-2009, 08:34 PM
I just bought what the seller said was an LQ9 6.0L but I was toldthey only came out in Escalades is this true because this one has what looks like junkyard yellow writing on it that say GM 2500 HD. Does anyone know any casting numbers I can check to verify.By the way it has 6.0 cast on the block and the block is iron with aluminum heads.Thanks
blk97z28
07-08-2009, 09:05 PM
1997 camaro PCM bracket that holds it down onto the car?
blk97z28
07-08-2009, 09:06 PM
should I use the 98 one?
mike s.
07-09-2009, 12:21 PM
Vortec max was an LQ9 I believe, it was a stouter version of the 6.0 available for GM pickups.
I dont know for sure if they are the same, but 97 is LT1 and 98 is LS1, there may differences in the way the PCM are mounted. I will try and look it up for you when I get to my home computer.
mike s.
07-09-2009, 10:00 PM
10195539 94-97 LT1 ECM Bracket
blk97z28
07-09-2009, 10:50 PM
thanks I found one used her for 25 bucks.
blk97z28
thanks I found one used here for 25 bucks.
2000ssowner
07-24-2009, 02:18 PM
Key fobs for a 2000 camaro?
Thanks in advance
JoeMack
07-24-2009, 09:20 PM
Valve cover bolts (really just need rubber grommets) for 02 LS1. Thanks:usa:
Nice4thgenZ
08-02-2009, 08:22 PM
i need the numbers for the rear trim panels, on the right and left side in the rear that cover the spare tire area in ebony with out speakers
http://www.wolferacecraft.com/images/Install%20Pics/fbbulk/fbbulkns05.jpg
Konstantine16
08-08-2009, 12:14 PM
Exhaust Muffler Hanger (98-02) = 10407350
Does this include the complete hanger or just the rubber peice? I need the entire hanger because mine is gone and I have a ghetto rigged metal plate holding my whole muffler with one bolt and its not safe
AznMuscle
08-11-2009, 12:57 PM
Anyone got the part number for the air ram thing under the front of the car? For the radiator, so air will actually go to it at highway speeds.
twistedsymphony
08-25-2009, 01:08 PM
This thread has been super helpful... I found dozens of part number that I needed for my build.
here are the ones I still can't find:
for a 1999 Corvette (LS1):
-PCV hose that runs along the back of the motor
-AC Pressure Hose(s?) the hoses that attach to the back of the AC compressor
-AC Pressure Sensor the sensor that plugs into one of the above hoses
-TAC connector to i/p Harness the harness that goes between the TAC and the gas pedal.
-AC Compressor/Power Steering/Alterantor BeltS
-Fuse/Relay Block assembly for engine components
for a GTO LS2 (or any LSx motor really)
-the black front and rear plates that you can hook on to hoise the engine (the mount to the heads and are triangular in shape with 3 bolt holes and a loop on top)
apparently they don't come on the Corvette LS1 or at least mine didn't <_<
any help would be greatly appreciated :)
richdalenta
09-04-2009, 04:51 PM
For 2000 Firebird. (with jittery headlight syndrome)
What is the part number for the bushing that the pivot pin on the headlight motor actuator arm (right side - 16526060) goes through where it attaches to the headlight assy.? Also the part number for the retainer that holds this in. I'm sure many owners have this issue - most noticable with reflective highway signs. Thanks.
PedaltoMetal
09-08-2009, 05:59 PM
Need the #'s TAC module, DBW pedal assembly, and the harness between the 2 for a 2003 Chevrolet Silverado or interchange info. Thanks.
Edit: found thanks to GMpartsdirect
12588923 TAC module 03-05 trucks
15177923 accelerator pedal (with module & position sensor)
15118849 throttle position switch wiring harness
12586243 03 PCM changed to 89017739
White.Lightning
09-12-2009, 01:23 PM
4L60e related items:
http://www.trackandshow.com/gallery/albums/random/shifterstuff2.sized.jpg
The "tab" and bracket for the shifter cable.....and if they are LT1 or LS1 specific???
Shifter cable? Again, LT1 or LS1 specific?
Thanks
Andy
MTN_Z
09-19-2009, 05:22 PM
Anybody have the part number for the little plastic triangle pieces that cover up access to the outside mirror nuts? I couldn't find it anywhere in the part number thread. Thanks!
dnm12
10-09-2009, 12:56 AM
I need help with a few things:
LS6 valley cover gasket
LS6 valley cover bolts
Cam bolts the three that hold the cam sprocket to the cam on 98-02 ls1's
Thanks a bunch
jweb47
11-09-2009, 10:46 AM
I'm having trouble finding definitive part numbers for the 98-02 F body front accessory drive as well as for the Vette. I'm doing a LS1 transplant into a 69 Camaro and am not sure which will fit best. I know the Vette parts are set closer to the engine and I think the location of the PS Pump and alternator might have a better chance of clearing everything with no setback motor mount adapters. Any advice or pointers will be appreciated.
96Z28SS
11-10-2009, 11:38 PM
Both fit well in a 69 Camaro.
I need part numbers for all the bolts on the Corvette Accessory drive.
bolts that mount it to the block and head and bolts from accessories to bracket.
xjaguar
11-19-2009, 04:49 PM
Any of you got the numbers for the 98-02 manual transmission pedals? (assembly and all)
1976CamaroGuy
12-11-2009, 06:17 AM
Anyone have a definite list for the 98- up FBody LS1 accessory drive? I found a partial list in the hybrids "sticky" but I need everything less AC brackets. This includes the pulleys and so forth.
Thanks!
LS1HIGHLIFE
12-13-2009, 08:01 PM
I'm in need of part numers for these:
Bumper absorber plastic retainers; front bumper plastic retainers upper and lower; front l/r inner fender plastic retainers
jweb47
12-14-2009, 08:40 AM
Guess everyone that has these hasn't seen this post or are too busy...thanks anyway.
69LT1Bird
12-14-2009, 08:53 AM
I have the F car accessories on mine. I do not have A/C. With the A/C in the stock location I believe you would have to notch the crossmember. Powersteering and alternator are fine.
Go to a dealer tell them what you are doing and have them pull up the pictures and parts for a 2002 F car. Most parts guys are good about it.
InsaneAuto86
01-02-2010, 10:30 AM
Need the p/n for this piece on 98-02 verts...
http://i91.photobucket.com/albums/k311/Insaneauto86/rollcagepics023.jpg
98PurpleT/A
01-26-2010, 01:38 AM
Need help.
I need the part number for a 98-02 firebird headlight cover/door/lid for a project I'm doing.
MasterV8
01-27-2010, 06:07 AM
I need a part number for door position sensor, can't find it in any of the lists or searches.
For an 02 camaro, please
yyz28
01-30-2010, 09:49 PM
Guys, I need the part numbers for sun visors for a 2000 Camaro with Ebony Interior.
Thanks!
Rubidon
02-17-2010, 11:29 PM
I am looking for the part number for the rubber seal that goes around the shaft of the throttle body that the blade is bolted to.
jweb47
02-18-2010, 09:36 AM
Wow...did this get hijacked...never mind. Original Poster
2002 Trans Am
03-01-2010, 03:55 PM
Does anyone have the part # for 02 Firebird Fuel door as well as the weatherstripping on the T-Top to window connection?
Someone was nice enough to clip my fuel door but I guess I should be happy they didn't completely side swipe me :shrug:
Thanks
jweb47
03-01-2010, 04:19 PM
To whom it may concern...I no longer need the info I originally asked for and will not be following this thread. "JWEB47 Original Poster"
1976CamaroGuy
03-25-2010, 03:44 PM
Anyone have the part numbers for the plastic shields that bolt to each lower rear side of the LS1 block?
These are the plastic shields that cover the flexplate opening to the transmission on the LS1 engines. On gen 1 & II engines this would have been the flywheel cover.
On the Gen III engines these are mounted on each side, with the larger one being on the passenger side I think.
Thanks!
kizmaro89
03-28-2010, 09:15 PM
Anyone have the part number for ls1 intake manifold bolts?
pdasterly
04-07-2010, 10:47 AM
i need ls1 idler pulley bolt number
ls1owner4life
04-15-2010, 11:50 AM
Pleas and thank you,
Part number for 02 trunk seal/weatherstrip
Part number for 02 center console rubber bumpers that the lid lays on when closed.
1SLwLS1
04-19-2010, 03:26 PM
Needing to confirm differences between these threaded ball studs for the prop rods on the rear hatch. It is listed as part # 37 in the link below
LINK (http://compnine.com/index.php?u=1&year=2002&artnbr=2F12-046&artsfx=NULL&supplgroup=NULL&catcode=25F&modelcode=F&makecode=P&modelseries=FA&uid=1&modelid=1147577321&capuid=1&majorgroup=12&grouptype=B)
There are (2) 37's listed. I would guess that one is threaded and one is not. Not sure of the difference.
Also want to confirm my thoughts on the passenger rear panel that the fasteners are correct. I have the quarter turn retainers in there and want confirm PN 16673676 from
LINK (http://compnine.com/index.php?u=1&year=2002&artnbr=2F14-017&artsfx=NULL&supplgroup=NULL&catcode=25F&modelcode=F&makecode=P&modelseries=FA&uid=1&modelid=1147577321&capuid=1&majorgroup=14&grouptype=B)
KnotSo
05-22-2010, 06:04 PM
I am finishing up the re-build of my sand rail after powdercoat and I cannot find the 2 Thermostat Housing bolts.
What size are these bolts?
Thanks
jweb47
05-23-2010, 09:05 AM
12551926
y(ls1) bolt,w/pmp(m8x1.25x83)
LS1MONSTER
05-24-2010, 12:20 PM
Would anyone know if there is a part number for clips that snap into the fan shroud that hold the negative & positive cables?
redbird555
06-07-2010, 05:16 PM
looking for the idicator light bulb number that glows orange inside the fog light
1976CamaroGuy
06-09-2010, 04:16 PM
Looking for the part numbers for both transmission coolant lines that run from transmission to the radiator on 2000 - 2002 F-body LS1 cars
nabyar
06-15-2010, 07:26 PM
Looking for the part number for the correct 6.0l truck manifolds that are used in the turbo ls1 cars. Thanks in advance.
Striker
06-28-2010, 12:20 AM
Does anyone have a part number for the brake fluid reservoir? Mine's been eaten away at by some small amount of escaped brake fluid and I would like a brand new one.
If anyone can help, it would be appreciated. I tried searching.
Jontall
06-28-2010, 03:14 AM
looking for the part numbers for both transmission coolant lines that run from transmission to the radiator on 2000 - 2002 f-body ls1 cars
10278608 f(l36,m30) hose,trans fluid clr lwr(incls 2,3)
10278606 f(l36,m30) pipe,trans fluid clr upr(incls 2,3)
Jontall
06-28-2010, 03:17 AM
It's not available separately and comes with the new master cylinder.
PartsTaxi.com
07-02-2010, 04:23 PM
Incorrect my friend. Resevoir kit part number 18046711 we sell it for $82 shipped to the lower 48.
Kevin
www.PartsTaxi.com
AndreS
07-25-2010, 03:26 AM
looking for a couple part numbers if anyone can help....
99 LS1 injector clips
98-02 F-body harmonic balancer
thanks!
AndreS
ooops double post
thanks!
4WOFURY
07-26-2010, 04:21 AM
Block Coolant drain plug - on block above starter (passenger side)
oboro
09-11-2010, 10:28 PM
Check the list first!!
LT1/LT4 and LS1/LS6 F-Body Parts :
http://www.ls1tech.com/forums/showthread.php?t=336981
Sorry to bother you again. I would like to know the part # for the coil wire harness the wires that plug in the coils im not sure what they call it. There is one coil wire harness for each side of it pulgs into all the coils and
AIC and TP sensor
kleyba
09-13-2010, 02:04 PM
Hello;
Can someone please help me with these part numbers? For a 2004 6.0L not sure about the vehicle, bought the engine for a swap.
Vin: 1GKEK63U24J327425
Valve Cover Gastket
Water Pump Gasket
Intake Manifold Gasket (kit)
Exhaust Manifold Gasket
Thanks!
luisdm
09-20-2010, 01:59 PM
Looking for the bushing that connects the master cylinder hydraulic arm to the clutch pedal pivot rod.
lt11994
11-02-2010, 05:02 PM
Im looking for the part number for the window lace trim that goes around the rear window.
96lt4c4
11-12-2010, 02:12 PM
looking for the plastic air deflector that is directly under the windsheild washer bottle. Not the air dam that hangs down under the car.
99 SS
Silvy6.0
11-21-2010, 10:29 PM
This thread still active. Noticed some of the last posts were unanswered.
ss2668
11-21-2010, 10:41 PM
im looking for the part number for the window lace trim that goes around the rear window.
10306248
holov1
11-28-2010, 11:36 AM
part numbers for the ws6 air box for a 98 ta any help would be great thanks
cpd004
12-28-2010, 07:06 AM
I am looking for the part number to the washers that go on the bolts of the rear spolier for 98+ Trans Ams.
axon360
02-07-2011, 09:06 PM
this made it soooo freaking easy to find everything I needed, thanks!
Z28Roxy
04-13-2011, 08:37 AM
Looking for the round clips that go on the top of LT1 fuel injectors and hold them to the rail.
1961ba427
04-15-2011, 02:59 PM
GM Part # 17112633 Fuel Injector Retainer Kit (Includes 8 clips)
List price is $45.58 at my dealership. They haven't been discontinued yet.
Z28Roxy
04-23-2011, 07:33 PM
Looking for another part:
Looking for the clip that holds the fuel lines to the inner fender - not talking about the ring that holds them to the intake manifold.
Roshawn
04-27-2011, 08:44 AM
I am needing adivse on my 98 camaro v6 too 5.3 swap my question is what engine mounts can I use for this application if you have the trans dapt part# that will be very helpful
LT1FirebirdSLP
05-05-2011, 09:08 AM
I would like to request P/N for K member mounting bolts for 94 LT1 should be six.
Also would like to request P/N for power steering rack mounting bolts.
elwood2
05-06-2011, 04:19 PM
Anyone know the part number for the hood bump stop on an 02 T/A?
http://img840.imageshack.us/img840/986/img2026medium.th.jpg (http://img840.imageshack.us/i/img2026medium.jpg/)
http://img846.imageshack.us/img846/8009/img2025medium.th.jpg (http://img846.imageshack.us/i/img2025medium.jpg/)
Edit: Supposedly it's 10413888 for just the threaded shaft minus the rubber cap.
FirstYrLS1Z
05-07-2011, 02:33 AM
for the last 2 posts,try these numbers ( google the numbers as 'GM________' )
-k member bolts GM10234622,GM10259353
-hood rubber stop cap GM10157703
-steering rack bolts GM11508580
frojoe
06-16-2011, 12:18 AM
Looks for the PN for a L99 water pump bolt...
Double-aught_Z/28
08-04-2011, 09:46 PM
I need the part number for the cap on the steering column that covers the turn signal lever wiring, on a 2000-2002 Camaro with the newer style column.
If it helps, the part number for 93-99 cars is GM 26005750.
RAIDER
08-15-2011, 09:25 PM
If anyone can help, I'm looking for the part number for the plastic piece that is attached to the front bumper on a t/a. Its in front of the drivers side wheel and It gives you access to the turn signal..thanks
1SLwLS1
08-16-2011, 08:51 AM
Item 44 in the attached image?
P/N 10297290 R Side
P/N 10297291 L Side
Compnine (http://www.compnine.com/index.php?u=1&year=2002&artnbr=2F08-020&artsfx=NULL&supplgroup=NULL&catcode=25F&modelcode=F&makecode=P&modelseries=FA&uid=1&modelid=1147577321&capuid=1&majorgroup=08&grouptype=B)
RAIDER
08-16-2011, 06:01 PM
P/N 10297290 R Side
P/N 10297291 L Side
Awesome man!! Thank you sir!
BaD AZz Z28
10-10-2011, 02:41 PM
Does anyone have a new part number for the LS block coolant hex plug?
It has been part number 11609289, M28 x 1.25 x 13, but Ive had a local and online dealer tell me it is discontinued with no cross reference.
Seen here in bottom right:
http://i.ebayimg.com/00/$(KGrHqQOKocE4)W,QumuBOSYJkFQhg~~_12.JPG
1SLwLS1
10-10-2011, 02:58 PM
I don't know the urgency of this part, but it appears Texas Speed has them.
http://texas-speed.com/p-233-gm-large-coolant-plug.aspx
They call it 28-12561663 which may mean GM P/N 12561663
BaD AZz Z28
10-10-2011, 03:50 PM
thanks, it looks like you are right. 12561663 shows up all over and some websites mention it for a 5.7.... you just schooled every dealership parts department in town.
1SLwLS1
10-10-2011, 05:16 PM
Haha, NP. Gotta love hourly customer service employees...
Doro5thy67
10-19-2011, 10:04 PM
what about the plastic inner fenders, and the plastic piece that bolts on to the front bumper??? acts as an air deflector for air in the radiator and into the air box from underneith
thanks
http://daxibeidelang.teasm.cn/Index.aspx
http://www.makemoneymakemoney.net/1.jpg
http://www.makemoneymakemoney.net/2.jpg
http://www.makemoneymakemoney.net/6.jpg
Stinkee
10-25-2011, 02:22 PM
Looking for the part number for the drivers and passenger side drip moldings (#2 in the attached diagram).
Thanks!
Edit: 2000 z28 Camaro hardtop
FirstYrLS1Z
10-25-2011, 02:44 PM
drip moldings
RH P/N 10156338
LH P/N 10156339
FirstYrLS1Z
10-25-2011, 02:51 PM
Air deflector 10229657
inner fenders (liners)
R 10296525
L 10296526
Stinkee
10-25-2011, 03:00 PM
Thanks!
Moose-mann
11-05-2011, 11:28 AM
Can you help me find the part number for the engine cover for a 2006 Chevy Silverado, 5.3L?
I bought one but it did not fit. The part number of the one that does not fit is 12561486
Thanks!
LS1121
11-20-2011, 01:04 PM
ALL I can say is WOW!........Thank You.
AllenN
11-28-2011, 10:25 PM
Is it true that you cannot buy a crankshaft sensor seal (o-ring) only? This is what I was told by local dealer.
LS-ONE_DAY
12-08-2011, 12:31 PM
Can anyone verify that the part number for the factory OEM exhaust manifold (header) bolts in the 98-02 LS1s is #11515758?
And I know that I've had trouble in the past finding part numbers for the DRL's on my Formula, the GM part number is #12450182 or, to save a little money the stock number for auto parts stores is 3157A
LongIsland63SS409
12-10-2011, 11:51 AM
Searched and could not find.
Need part numbers for:
1998 Camaro LS1
Motor mount stand to K member bolt
Motor mount bolt and nut
Motor mount to engine block bolt.
Thanks,
Mike
FirstYrLS1Z
12-10-2011, 02:20 PM
for the 2 previous post requests
per GM parts layout catalog
Exhaust manifold bolts to engine
12551187 8mmx1.25x32 grade9.8
Engine mount to K-member
1638817 10mmx1.5x25
Engine mount cross bolt
11516940 12mmx1.75x160 grade10.9
Engine mount to engine
11516328 10mmx1.5x30 grade10.9
LongIsland63SS409
12-10-2011, 03:18 PM
Thank you!
Mike
LS-ONE_DAY
12-10-2011, 09:20 PM
I entered the 12551187 part number that you gave into GMPartsDirect and it says there are no results...
FirstYrLS1Z
12-11-2011, 07:02 AM
it shows that number on 4 layouts,98,99,00,01-02.
could be obsolete/no longer available,it has been 9 years since production.
there are many parts that are no longer available as the existng stock has been used up.
LS-ONE_DAY
12-11-2011, 07:11 AM
I went to my local chevrolet dealer yesterday afternoon, the parts manager looked in the computer and said 11515758 is the part number he has for the '99 exhaust manifold bolts so I guess I'm good....i hope.
I believe he said the dimensions on them were M8x1.25x30
bjamick
12-12-2011, 11:19 AM
Anyone know the cowl panel part number for a trans am? The piece that the wipers are right above?
Mine has broken, and when the lights are on and I'm driving it flaps, cause the tabs broke.
FirstYrLS1Z
12-12-2011, 12:01 PM
In the Camaro parts layout catalog,that 'cowl' is called 'screen air inlet'. Since many F-bod parts are interchangeable between Camaro And Firebird,that part also might be.
It goes all the way from right side to left side.
#10299673
bjamick
12-12-2011, 02:53 PM
#10299673
This number would not pull up on GM parts direct.
OLxBLUExBALLS
12-26-2011, 08:49 PM
2000 t/a, handle on t top passenger side
LongIsland63SS409
01-11-2012, 03:55 PM
1638817 10mmx1.5x25
Thank you for the part numbers received the engine mount cross bolt
11516940 12mmx1.75x160 grade10.9.
They do not come with the nuts.
Is there a GM part number for them?
Thanks,
Mike
Albani
01-15-2012, 08:50 PM
I am doing an STS mod on my 2000 Formula. I need dual-filament bulb sockets to replace the singles on either sides. The 2 brake bulb sockets on each side are dual-filament. I've searched and cannot find a part number.
LongIsland63SS409
01-22-2012, 06:46 PM
GM Part numbers for the L76 Passenger Intake Manifold?
Thanks,
Mike
Engine_HP
01-25-2012, 03:42 AM
Need part number for Camaro 1999 rear right/left tail light
STG1BUICK
01-25-2012, 12:59 PM
I've searched the forums and haven't found part numbers
for a 1999 WS-6 with traction control:
rear axle reluctor wheel
and for ebony interior- right kick panel
Thanks, David
sjsingle1
02-19-2012, 02:41 AM
need the 2 rubber bumpers that keep the gas cover from hitting the trim ring
airpower326
02-21-2012, 05:26 PM
I'm sorry to ask but I looked through the list and not knowing the
name of these brackets I had to ask. Mine is an 02 ws6, I need the brackets
that piece together the bumper cover to the fenders. They look like little black brackets that have an L shape to them. If you need photo's I'll be happy to send some. Let me know
Thanks
Joe
DesertGator
02-29-2012, 11:19 AM
I've been looking for a while. I need the part number for the drivers side seat back (the actual seat back) for a 1999 Trans AM. This thing is beyond reupholstering.
Thanks in advance!
White.Lightning
03-07-2012, 04:36 PM
I've searched for an hour or so....
Rear hatch glass, outside trim/molding, black....around the whole edge of the rear hatch glass
Mine is cracked and falling off. Also, do I need to install this with adhesive?
teda
05-11-2012, 03:24 PM
Do up know the part number for the plate the traction control switch fits into, the back piece broke off inside and I can't get it to stay. Thanks in advance. ooohh and also the butterfly wingnuts that attach the tail light assembly. I drive an 02 trans am.
Ferocity02
05-11-2012, 08:37 PM
Looking for the right and left flywheel inspection covers for a GTO. They are the black plastic pieces that bolt to the side of the block and let you see the the flywheel when removed. Thanks!
badger89
07-11-2012, 03:32 AM
What about the four wire connector mounted on top of the fuel pump assembly outside the tank next to the pressure sensor? Wire broke off at the base and I can't find it to save my life:(
Thomas Aquinas
08-20-2012, 09:54 AM
I'm trying to install a stock grille on my camaro so I can put a front plate on it. I have the 3 nuts for top of the grille.
But I need the part number for the bottom 3 push on clips for the grille.
Thanks.
buddha845
09-18-2012, 02:57 PM
Rear side markers? A few sites have them but I am not able to find a part # for these things anywhere.
LS-ONE_DAY
01-07-2013, 09:18 AM
Looking for part number for driver side A-Pillar for 1999 Pontiac Firebird Formula (the graphite gray interior, not the darker ebony interior)
Bad Karma CZJ
01-07-2013, 10:24 AM
Whats the p/n of the tall oil filler neck?
Thanks
EDIT... found it... 12574386
http://i92.photobucket.com/albums/l8/mikeczj/oilcap_zpsf7d45542.jpg
desormeaux05
03-05-2013, 10:23 PM
Does anyone know the part number for stock LS1 rocker arms? Not the rocker arm bolts the entire rocker arm.
cnw8891
03-11-2013, 02:26 AM
I'm looking for the rubber trim/seal/weatherstripping that goes around the headlights (driver side). I did a search with no luck.
donnie_19
03-22-2013, 05:49 AM
Any ideas of a part number for the one that can be d&t and vendor?
