What fuel pump and brand of remote bottle opener?
Old 06-15-2005, 09:33 AM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Default What fuel pump and brand of remote bottle opener?
I have a ny-trex wet nitrous system and I am going to need a remote bottle opener since the bottle will be mounted in my tool box what brand has everyone had good luck with and what did ya pay for it. Also what kind of heater? I want to upgrade my fuel pump too so I dont run lean what kind do I need. I will be spraying on a 6L and a 150-175 shot.
Thanks, Cody
Old 06-15-2005, 09:38 AM
Closed ex-Sponsor Account
NXRICKY's Avatar
Thanks, Cody
Walbro, or Racetronix on the pump. The open NX, or ZEX. Depends on the type of bottle valve. Stay away from the solenoid style valves. You would have to get out open the bottle manually and then get back in and throw a switch to open the line.
Ricky
Old 06-15-2005, 10:35 AM
1slow01Z71's Avatar
What size pump should I get?
Old 06-15-2005, 11:15 AM
Matt@HSW's Avatar
I would run the Racetronix system, or if you are a do it yourselfer, then you could just go with a 255 liter pump and build your own hot wire kit for it.
Old 06-15-2005, 11:41 AM
LS1TECH Sponsor
DynotuneN2O's Avatar
our heater kit is currently on sale for $139....Check them out
www.dynotunenitrous.com
Dan
