timing and AFR from Tech 2 scanner...
Just wanna know how accurate the tech 2 scanner is....Before I spray my car w/ the 150 shot I figure I get some n/a readings... I have a tr224 cam 563 563 w/ a 111 lsa....My Pcm is a virgin/Untuned...my timing was reading 23* in 1st gear @ WOT and Air fuel ratio was 11.4/11.6:1 in 2nd gear @ WOT...somebody told me that the tech 2 scanner isnt to accurate....thanks
Originally Posted by WS6FirebirdTA00
whats the reading on the o2s, the mV?
I brought the tech 2 scanner back to work..Ill have it again tommorow...do I read the 02s mV @ WOT?
Bank 1 sensor 1 950-963 mV @ WOT
Bank 2 sensor 1 950-954 mV @ WOT
Double check timing again and got 24* @ WOT in 1st gear....
