help me.. different sound from clutch
Old 06-19-2005, 07:58 PM
CT Hotness
lilstephsls1's Avatar
Default help me.. different sound from clutch
i was on a side road near my house practicing some launching and powershifting and when i pulled back into my driveway, i put the car in neutral and took my foot off the clutch and i noticed a weird sound so i listened close to the shifter and it sounds like lighting clicking that the clutch is making while its spinning. when i put my foot back on the clutch, this noise goes away. is this normal or should i be concerned? btw, its a new spec3 clutch/flywheel with about 700 miles on it. any advice, help, or suggestions are greatly appreciated
-steph
Old 06-19-2005, 08:45 PM
smokeum99ta's Avatar
I beleive that is the chatter noise that spec clutches are known to make. I have a spec 4f and it does the same thing.
Old 06-19-2005, 08:48 PM
CT Hotness
okay, i wasnt sure if that was the noise that they were supposed to make. i'm a worry freak
Old 06-19-2005, 11:25 PM
Ditmeion's Avatar
Kinda sounds like it might be throwout bearing noise...did you replace it during install? Did you replace the slave?
