Hooking up the clutch line???
Old 06-19-2005, 09:38 PM
'02 SLP#686's Avatar
Default Hooking up the clutch line???
Having trouble putting the clutch line back on the tranny??? It should just push in right? Any tips or secrets would be great
Old 06-19-2005, 10:11 PM
JRracing's Avatar
It should just slide back in. Check the clip out on the hose. Try to check in the hole, make sure it's clear of any thing. Use a mirror if you have to.
Did you just take it out.
Why did you take it out? Did you replace the slave or master?
Mine slid right in!
Old 06-19-2005, 10:18 PM
Just finished my motor swap
I did notice the plastic ring on the line is cracked, but that shouldn't make a difference. Sigh, it is all I have left to drive the car with the new motor
Old 06-19-2005, 11:03 PM
99hugcam's Avatar
Happened to me. I had to pull the tranny (throwout and slave) far enough out so there was no pressure on it. Worked for me?
Old 06-20-2005, 05:26 AM
Wonder if I could open up the bleeder on it to relieve some pressure?
Old 06-20-2005, 06:21 AM
991LE's Avatar
That is the answer, just relieve a little pressure and it will slide right in.
Quick Reply: Hooking up the clutch line???
