about to install cam, what to change
lots of things, do a search for it and you will see a lot. i did this before my cam install.
you will have to increase the timing to about 22 for idle cells, not sure the exact ones but you can find it in a search. you will prob have to scale the ve down some in the first few columns. you will have to adjust your idle, your idle airflow....there are some others im sure im leaving out as well.
