how much is this T56 swap setup worth??
ok, i may be getting another T/A soon, a 97 6 speed. how much can i expect to get from selling the T56 with clutch, pedals, master cyl/hydraulics, etc for? basically this would be almost everything needed for someone to do a conversion except for the PCM. I will be putting a tH350 in the car...
well the t56 for the LT1 is different so you would have to find a person who has the lt1 and want to convert. Alittle harder to find.
As for the standard ls1 conversioned t56 you could ask 1000-1500 depending on what has been done to the trans, how many miles.. what type clutch.. flywheel type?
Thats a very faigue question you have there. I would need to know more.
I would say for a stock 70-90 thousand mile trans and everything else as well as stock clutch.. 1000bucks.
Are you including cross member and trans mount/console/shifter/shifter ****?
yea i would say 1000-1200 for it depending on miles. As for being hard to sell, i dont think so anyone who wants to put a 6 speed behind a sbc has to use on from a lt1 becuase of the out put shaft.
Justin
Justin
