wideband vs o2 voltage results
LS1TECH Sponsor
What this chart is showing is that between the AFR ranges of 12 through 14, there is about a 300-400mv difference in O2's..
Meaning the wide band AFR results are much more accurate.
The chart also shows that a 13 AFR and a 14 AFR will result in very similar O2 mv's. What that says is if you have an O2 mv within that range, you don't know if its 13.0 AFR or 14.0 AFR.
- Keith, HP Tuners
- Keith, HP Tuners
