removing all computer and fuse block wires need some help
like the title says im removing all the wireing in the engine bay the computer wiring runs into the car that i seen is there a disconnect in the dash somewhere? im also removing the fuse blocks cause i got some melted wires to replace i took the bolt out of the firewall to the block but it still wont move anyone know whats holding it please let me know kind of at a set back right now
Left hand side of the steering shaft is a connector with a bronze color bolt and there is also another connector the connects to the top of the steering shaft that needs to be disconnected as well... once everything is disconected and the 7mm bolt is removed from the bulkhead it all just comes out throught the firewall from the inside.
