Turbo setup
Old 06-26-2005, 11:24 PM
BOOSTIN86's Avatar
Default Turbo setup
Hi, im kinda new to the forums, ive been doing some searching and cant seem to find pistons that go below 9... in the compression. I am going to away to school soon and am about to by a short block to build. Other then alummium being lighter....should I go alumminum if im doing a turbo setup? obviously alumminum tends to warp under a lot of heat. Any comments?
Old 06-26-2005, 11:31 PM
FastKat's Avatar
There are guys running a ton of power through aluminum blocks... and they don't warp under even extreme usage. So far the only identified problem I am aware of is main bearing cap walk on some extreme engine setups... so I guess the block flexes a little when pushed to some serious limits... I think the agreed consensus is around 750rwhp.
Check out the Forced Induction section
Old 06-26-2005, 11:41 PM
BOOSTIN86's Avatar
Yea that will happen under pushing any motor to the limits...and i apologize for my ignorace for the ls1
Old 06-27-2005, 12:06 AM
BOOSTIN86's Avatar
other then qestion were i can get the pistons....were can I get a 6.0 cast iron block? By the way i planb on puting this in a gto
