Neutral Safety Switch in M6...
I would like to know if and how the NSS is connected in an M6 F-body. Particularly 99+. I have the pinout for the computer. I am trying to trick the computer in thinking it is in neutral or park to set the rev limiter at a launch RPM then release a switch to operate as normal. Where in the ECM is the Clutch switch connected to? This is not part of the NSS circuit is it? I am ultimately trying to rig a 2 step using HPT's rev limiters.
Thanks
Thanks
I located the pin of the NSS on the PCM. On the M6 there appears to be no connection which leads me to beleave if I put in a pin and a wire I can place a switch in and fake it into thinking there is a NSS. Any thoughts on this?
