Driveshaft length???
Old 06-28-2005, 08:04 PM
TT-TECH Veteran
Inspector12's Avatar
Default Driveshaft length???
I was wondering if any of you guys knew the length of your driveshaft with a 12 bolt and a 6spd I am trying to buy one and I don't know the length needed. Any help would be appreciated.
Old 06-29-2005, 05:25 AM
TT-TECH Veteran
To the top for more views and to see if anyone has any information.
Old 06-29-2005, 08:08 AM
777's Avatar
Probably be best to contact the rear-end manufacturer.
Old 06-29-2005, 08:41 AM
jerflash's Avatar
when i installed my 12 bolt i had to cut an inch off the stock langth of the shaft
the only reason i had to do this is because i had the "billit" 1350 yoke on the rear. if you get the regular 1350 or 1310 yoke you dont have to cut the ds.
when i searched this was the info i cam up with and when i did my rear it was exactly what i had to do
Old 06-29-2005, 09:06 AM
TT-TECH Veteran
Thanks. That is the kind of info I was looking for. I have a 1350 so I'll whack off an inch. Thanks.
Jeff
Old 06-29-2005, 11:08 AM
jerflash's Avatar
but what kind of 1350 do you have?
there is the regular or the billit one
make sure its the billit before you hack
Old 06-29-2005, 11:25 AM
Fulton 1's Avatar
Jeff,
You're best bet is to talk to your driveline manufacturer and see how they require the measurements.
For example, Denny's uses this procedure: http://www.dennysdriveshaft.com/html/how_to_measure.htm
In my case I used template B ( http://www.dennysdriveshaft.com/html/b.html ) when ordering my Denny's and came up with a length of 44" with MN6, Strange 12-bolt w/1350 yoke, and car lowered about 1.5". This turned out to be the exact same length as the stock driveshaft:
Old 06-29-2005, 04:19 PM
TT-TECH Veteran
Yeah it's Billet.Thanks! Thanks Fulton 1 I had already called a few people and it just depends on who I am haveing make it etc... Just like you said. Thanks.
Jeff
Old 06-30-2005, 07:19 AM
1ScrudeDude's Avatar
My shaft was 44-3/4 ".
I errr, mean, my stock driveshaft
