Tuning for 97-98 Vette...
I'm using HPT and want to know what I should do different since these years have the vacuum fuel pressure regulator. Should I put an adjustable regulator on or set something different in the editer?
Thanks,
Joshua
Thanks,
Joshua
If you just want to do basic tuning you don't have to do anything, I have yet to mess with the regulator or anything in the PCM regarding. If you want to SD tune you will need to send your .bin to HP Tuners first so they can fix an issue with the tranny shifting excessively hard on failing the MAF.
I forgot to add that the harsh shifting issue is for A4's...
