can any one help me to tuning camshift
Hi to all just i have question if any one can help me , i have camaro Z28 2002 model and it A4 transmission ,I chang the cam to :
Advertised Duration: 269 int./273 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.525
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.532
Valve Lift with Factory Rocker Arm Ratio: 0.525 int./0.532 exh. lift
Lobe Separation (degrees): 114
so can any one till me what i have to chang from the ls1 edit because i don't now what to do,,
thank you ,,,,,,,,,,,,,,,,,
That's a small cam, you may not need to do a lot for drivability. You might bump the idle to 700 or 750 rpm and find that does it.
For performance, I would raise the shift points to 6400 to start.
Take a look at the tuning for newbies sticky at the top of this forum to learn the basics.
