Anyone running FAST 90mm, 85mm MAF, TNT power ring??
I can't get my system to fit right. I have an 85mm maf, 90mm TNT power ring and 90MM FAST setup. With no coupler the MAF is almost touching the power ring but the maf is about a 1/2" higher then the power ring. Is anyone running this setup. Did you have to do anything to get it to fit? I didn't trim my lid any but I think that would just make the alignment worse. Thanks a bunch for any help.
Moderator
I don't have the same setup, but I had a similar issue when I installed my TNT kit. I just trimmed my lid at an angle to get it even with the ring, and then put a fernco in between the ring and the MAF. It takes alot of cutting and trimming to get the fernco right but it works and only took like an hour.
