fuel pressure bleeding off
I have been having a fuel pressure issue for a few days and need a little help.
After installing a new torque converter my fuel pressure dropped from a constant 59#'s to 56#'s and would drop to 42#'s at WOT. I had the tank dropped and tightend the lines on the Walbro pump. Now pressure at idel is 59#'s but drops to 52#'s at WOT.
I pressureized the system by turning the ignition on and building pressue. The system goes to 59#'s immediatly, then drops to 46#'s and bleeds down almost 1.5# per 30 to 45 sec's.
I know that the fuel lines are not kinked or damaged. I just replaced the fuel filter. The injectors are not visually leaking.
Where do I go from here?
Thanks in advance
Thanks in advance
Pressure
After rechecking with a manual gauge, at idel the car maintains a constant 61#'s. Under heavy accerleration it drops to 52#'s. Also, the manual gauge shows a drop of 10#'s per hour when the system is presurized and not running.
I am not sure what the other valve is. I know there is the pulse dampner on the fuel rail, there is a vent by the rear brake assm., there is the pressure regulator, and the sending unit. Where is the other check valve?
with engine running, and pump constantly running, it wouldnt matter if three was a check valve or not.
If the pressure is dropping, you either have a leak, or the pump cant cope for some reason. If its happening at idle or thereabouts, when there is virtually no load, or fuel needed, then you probably have a leak.
I think you are correct.
After going throught the GM service manual, its either a bad fuel pressure regulator, bad fuel pump or broken or loose line in the tank. Either way I have to drop the tank again...I will post more when I inspect the guts of the tank. Does anyone know if GM sells just the fuel pressure regulator. I should just replace it while I am there...
I will try first
I 'll try with replacing the hose first. Just to make sure I am clear, you are talking steel braided hose or the hose with the reinforced threads in them.
the stock gm fuel pres regulator is a POS...upgrade it or at least replace it...i think its like 4 bucks from gm.......its insanely cheap...mine crapped out ....pres was very low......I would go with a external regulator in the return line
4 bux
You have to be kidding me. There is no way its $4.00. I researched this and GM lists the whole assembly for $450. According to GM it is the only way to get the pressure regulator. However thanks to one of the sponsors I found out the intank pressure regulator is the same as a 97 vette fuel rail regulator which GM sells seperatly. Cost $70. Please let me know if there is a better deal.
Thanks in advance
Thanks in advance
Holy Chit
Wow did one of the sponsors really give it to me in the ***. They charged me 63.55 + shipping for the regulator while SDPC sells it for $45.00. Someone is getting a call Wednesday.
h,mmm i had priced it at the local dealer for 3.95............i can check tomorrow with them if you like...........also another option would be to use the vette fuel filter...it has a built in regulator...but its prolly 50 or so...unfortuneatly plumbing in a external reg may be a problem because of the special tools required to properly shape the metal tubing ......brass compression fittings seem to leak fuel too easily at the pressures the fuel system runs at.I don't know what pressures standard flare fittings can handle.I've seen the tools needed @ around 250 dollars to make the oring type ends on the lines......then you would need the female threaded fitting to screw into the external regulator.I have a stock fuel pump-regulator *** ...i can look at it tomorrow and see what other options are possible
Thanks
If you can check that price I would appreciate it. Also a vette fuel filter with regulator would not work on a return line system from what I understand. The pressure would bleed out the retun side...
