ok anything else i need
ok anything else i need?? do i have enough fuel??
alright guys i got a dyno day coming up and i'm putting the new kit on the car.. heres the specs
10 lb bottle
ice man pure low noids with purge
dual nozzles
walboro 255 in tank..
ngk tr7's
now i'm wanting to spray 225 for the dyno day timing is set at 26* car has a nice rich tune in it.. and it will have plenty of good gas in it... 112 octane.. i use it in my bike so its here.. its probably over kill but it'll b worth the few hp loss for the safety margin.. now is that 255 going to provide enough fuel?? oh it is of course a wet kit...
where can i get a 340?? its a 98 car so it has 28.8 injectors
thanks for n e input..
Mike
10 lb bottle
dual nozzles
ngk tr7's
Mike
I didnt see a window switch on that list.Make sure you have one.
As far as the walboro 340.We sell them however they are prettymuch the same as the 255 fuel pump you have.If your setup is overusing the 255 I would look into upgrading your fuel system into the racetronix system.
How much are you looking to spray?
Dave
Dave
i'll be spraying 225 on the dyno..
so there is no real difference between the 255 and the 340??? so it looks like racetronix is the only other option.. i don't know if i'm over using my pump.. we shall see on the 16th i guess..
Mike
Mike
