rear end ID.......
Old 07-04-2005, 10:52 AM
iquois's Avatar
Default rear end ID.......
How can I tell if rear end is 3 or 4 channel?
Old 07-04-2005, 10:56 AM
ls2 bait's Avatar
3 channel = no traction control= reluctors pressed on gear
4 channel = traction control= reluctors pressed on axles
Old 07-04-2005, 03:12 PM
iquois's Avatar
Default traction light
So.....if I have a "traction low" light on dash when I get on it, I have a 4 channel?
Old 07-04-2005, 04:35 PM
SupahRich's Avatar
Nope, that means you're having traction issues, for me that light comes on when I get on the brakes hard when its been raining.
Are you asking if the rear that's currently in your car is 3/4 channel or if a rear you're thinking about buying is 3/4channel? If it's the rear already in your car, do you have a switch at the front of the console, below the radio to turn TCS off/on? That's the easiest way to tell what you have of course. If it has the TCS switch, it's 4 channel. You can also look under the hood, behind the battery... if you have a component mounted to the body of the car with a black top and the throttle body cable goes in to it, then you have TCS.
Old 07-04-2005, 04:56 PM
2001NBMZ28's Avatar
Also the 3 channel (NON TCS) rears have one sensor on top of the pumpkin, the 4 channel (TCS) rears have two sensors, one at each rear wheel.
Old 07-04-2005, 06:03 PM
iquois's Avatar
Default Tcs
I do have the TCS switch............Thanks !!!!
